New to the FTM-350.
Just tring to follow the APRS manual for preparation.
Leaving the default Data Band Select at 1 APRS Sub Band and 2 Data Main Band it si not possible to get the the display shown on page 3.
Adjusting the Data Band Select to 1 APR L Band Fix and 2 Data R Band Fix the display can be obtained shown on page 3.
Receiving a APRS Beacon appears as shown in the manual, page 4 & 5.
Now the problem: on page 8: Manual or Automatic transmission gives a TX ERROR that appreas on the L-Band side of the display.
If anyone has had the same situation please reply to the post. I have reset the FTM-350.
If you have a different Band Select that works, that would be helpful information.
Advance thanks to all for any help or direction.
Tim Tucker writes:
<<The A12 only flashes if you have auto-beacon turned on. The common reason why it won't transmit a beacon is probably because you have the data/aprs modem assigned to the other VFO than the one you are trying to beacon on. I set my data/packet modem to always be on the right VFO so that I know to select that one when trying to transmit APRS packets. >>
Tim Tucker writes:
