    Dismiss Notice
Dismiss Notice
IRF520A
Discussion in 'Home Brew' started by Crusher, Mar 2, 2008.
  1. Crusher
    Crusher Well-Known Member
    May 12, 2007
    837
    353
    I was wondering, what is a clean reasonable number for an amplifier using (4) mosfets that were mentioned above?
  2. mackmobile43
    mackmobile43 Jock Supporter
    Feb 11, 2008
    6,700
    390
    100 WATTS PEP GIVE OR TAKE
  3. Crusher
    May 12, 2007
    837
    353
    I do not have a peak at the moment, I am getting about 35-40 watts average on a Bird. Just wondering if this would be considered reasonable or acceptable.
  4. DIRTYWHITEBOY
    DIRTYWHITEBOY Active Member
    Feb 17, 2008
    251
    11
    Are you sure its tuned correctly? What is your bias voltage? I get 400 pep out of 16 irf-520s,works out to around 25 pep per mosfet on mine.I have my bias voltage set at 4 volts.
  5. freecell
    freecell Active Member
    Apr 6, 2005
    1,702
    364
    100WPEP = 37.5WAVG..
  6. mackmobile43
    Feb 11, 2008
    6,700
    390
    tomato, tamatoe
  7. freecell
    Apr 6, 2005
    1,702
    364
    it's working fine Crusher.
  8. Crusher
    May 12, 2007
    837
    353
    Dirtywhiteboy, I biased amp so that it would draw 40mA. That is 10mA per transistor. I originally biased circuit for 4.5 volts. But I found out that it is not long before replacing mosfets. I used part of design from the Ranger 94VHP. Also took a few ideas from the ARRL Amp Classics book section on mosfets using the 510 and 511's. Between the 2 this gave me a good place to start. I can't believe it only took about 160pF cap. across the output transformer. I usually am used to using something like 5 or 6 times larger.
  9. GRTS
    GRTS Galaxy Tech
    Apr 28, 2005
    110
    3
    What's a Ranger 94VHP?
  10. Crusher
    May 12, 2007
    837
    353
    I think it is actually a Galaxy 94VHP. It is made by Ranger. It has 4 irf520's im the final section.
  11. GRTS
    GRTS Galaxy Tech
    Apr 28, 2005
    110
    3
    Thanks for that info Crusher.
    (y)
  12. Crusher
    May 12, 2007
    837
    353
    I hooked up my LP-100 and used it in pep mode, I get right about 110Watts. Onn SSB I get about 117 watts.
  13. Crusher
    May 12, 2007
    837
    353
    GRTS, Galaxy has a model called 98VHP. It has 8 IRF520's as final section. Might want to take a look at that as well. Going to try a few other projects with IRF550's and IRF35X series. Anyone know how I can post a pic of this project?
  14. AudioShockwav
    AudioShockwav Extraterrestrial Admin
    Staff Member
    Apr 6, 2005
    6,561
    3,373
    You Have a PM.
  15. AudioShockwav
    Staff Member
    Apr 6, 2005
    6,561
    3,373
Share This Page
  • About Us
    The WorldwideDX Radio Forum was originally established in 2001. We pride ourselves on welcoming Radio Hobby enthusiasts of all types, while offering unbiased, informative, and friendly discussion among the members. We are working every day to make sure our community is the best Radio Hobbyist's site.
  • Like us on Facebook
  • Premium VIP Member
    The management works very hard to make sure the community is running the best software, best designs, and all the other bells and whistles. Care to buy us a beer? We'd really appreciate it!
    Donate to us!
