    Dismiss Notice
looking for any info. on a sears base
Discussion in 'CB and Export Equipment and Accessories' started by w527, Apr 6, 2002.
  1. w527
    w527 Guest
    good evening all, i'm looking for any info. i can find on a sears model 60105 AM base. i can find all sorts of PLL info., but no tune-up or mic wiring for it. it's the PLL O2A chip and is a 40 channel model(for now). any info. would be a big help. well time for work, have a good night all!
    thanks,
    Bob - W527
    </p>
  2. Laserbeam
    Laserbeam New Member
    Oct 2, 2018
    4
    I have a Sears 60105 40 chan AM base. It's an extremely rare model. Would like to find some mod docs for it. 20181001_162249.jpg
    #2 Laserbeam, Oct 2, 2018
  3. sonoma
    sonoma Sr. Member
    Sep 14, 2005
    2,051
    816
    go over to cbtricks.com and look under the secret CB books. there may be some thing over there. most sears radios have a number like 934.678954. not just 6105. at least all I ever saw had a long list of numbers.
    Laserbeam likes this.
  4. Laserbeam
    Oct 2, 2018
    4
    I checked, there are no other numbers, just a DOC number and 2 serial numbers. This one is a real enigma! :)
  5. nomadradio
    nomadradio Analog Retentive
    Apr 3, 2005
    2,550
    2,243
    A clear, readable close-up pic of the serial number plate might help a lot. Should reveal the full Sears catalog number.
    The "DOC" notice means it's a canadian radio, not a USA model.
  6. Laserbeam
    Oct 2, 2018
    4
    Here is the plate. For some unknown reason the DOC number was defaced, but it can more or less be still read.
  7. TM86
    TM86 Ooohhh, shiny!
    Jul 6, 2014
    321
    277
    Found a Sears 60105 in my copy of the CB PLL Data Book. That has it as a Cybernet chassis PLL02A "Late Generation AM 2-Crystal Loop, 40 Channel."
    I'm guessing if you open it up there's a board number on the main circuit board along the lines of "PTBM057COX" or something like that. With the board number someone here should be able to find a similar enough radio that a Sam's or other service manual could be found, if indeed it's what my book claims.
  8. Laserbeam
    Oct 2, 2018
    4
    OK I think I have the board ID here. PTBM050COX
  9. sunbulls
    sunbulls Well-Known Member
    Apr 25, 2017
    344
    497
    That’s a big help. The RCA Co-pilot 14T303 has that same board. Several other RCA’s also use that board, but they’re mobile radios. I think the 14T303 base with the power supply schematic will be a closer match your radio. You can find the service manual and schematics on CBtricks.
    http://www.cbtricks.com/radios/rca/14t260_70_14t303_4_5/index.htm
    Note: The minor difference between your radio and the 14T303 is the Co-pilot has an additional small board that contains the built-in SWR circuit and a metering circuit that runs the modulation meter. Your radio doesn’t have those two features, otherwise they’re basically the same.
    #9 sunbulls, Oct 2, 2018
  10. nomadradio
    Apr 3, 2005
    2,550
    2,243
    Good call!
    Simpson-Sears Limited of Canada used a whole different numbering system for their CB models. Howard Sams only covered USA-approved CB radios.
    The scratched-out gummint-approval (DOC) number suggests to me that it was either printed wrong, or had been submitted for approval a second time, and given a new number. Maybe?
    But the sticky label above the serial plate says "DCO", not "DOC".
    Don't see a lot of dyslexic ID labels on the rear of radios.
Share This Page
  • About Us
    The WorldwideDX Radio Forum was originally established in 2001. We pride ourselves on welcoming Radio Hobby enthusiasts of all types, while offering unbiased, informative, and friendly discussion among the members. We are working every day to make sure our community is the best Radio Hobbyist's site.
  • Like us on Facebook
  • Premium VIP Member
    The management works very hard to make sure the community is running the best software, best designs, and all the other bells and whistles. Care to buy us a beer? We'd really appreciate it!
    Donate to us!
