strain relief mic cord boot
H1driver
Supporting Member
Feb 13, 2011
144
188
53
Needing to re-wire some older hand microphones with new cords. Does anyone know a vendor for a strain relief boot to go at the mic to transition down to the smaller cords? I have the tubing sleeves to go at the plug end so the plug will clamp correctly. Thanks for any information.
I always use a couple layers of heat shrink. Looks good and works good.
what he said, i do it exactly the same way.
depending on the diameter of the mike cord you could also use a bit of sheath from 5 or 6mm coax too, or any other sheathing from multicore mains flex thats the right diameter.
Another option is a rubber grommet. When you tighten the case screws the grommet will apply pressure against the cord and hold it firmly in place. ;)
    Tucker442 has left the room.
    LIVE 10:00 AM EST :cool:
  • @ Charles Edwards:
