To start with, if you are not checking things into a dummy load, then the accuracy of your findings are suspect.
If you feed that amplifier a signal with a 1:4 ratio, you should see a 1:4 ratio on the amplifier's output. If you don't then I would recheck the radio you're using for that 1:4 ratio. If it really is that 1:4, and the amplifier isn't reasonably close to that, then you can certainly assume that amplifier isn't very 'linear'. Try reducing the amount of drive power (50% maybe) you are feeding the thing and check it again. Still an unreasonable result? Take a good look at that amplifier. Lots of things are 'claimed', a few of those claims are even correct,or close. Some are just plain BS. Which do you have?
(The same will hold true for any amplifier, doesn't matter who makes it.)
