It's a fairly simple thing to understand. You want to get something from point 'A' to point 'B'. That 'something' has a certain 'size' and 'shape'. So, the path from 'A' to 'B' has to be a certain size and shape to let that 'something' pass along it without a lot of trimming of that 'something' to fit the path, or without a lot of work changing that path. That's reasonable, isn't it?
Once that 'something' gets to that point 'B', the door in point 'B' has to be of the right size and shape so that 'something' can pass easily into point 'B' without having to be changed to fit that door. Or the door has to be worked on so that the 'something' can pass through it. That's reasonable too, right?
One of the requirements is that the 'something' going from point 'A' to point 'B' can't or shouldn't change size or shape. If it does change then you wasted all that work in making that 'something' into the size and shape you wanted, it isn't 'perfect' anymore, real bummer! So, that means you should have a "yardstick" (measuring device) that can tell you if the 'path' you want the 'something' to travel is the right shape and size. That "yardstick" can also tell you if the door into point 'B' is the right size and shape. So that means that you'd better know how to use that "yardstick" (measuring device), right?
So what happens if that door, for instance, is the right size and shape, but it's rotated 90 degrees? That 'something' will still fit through it if you tilt the 'something' sideways, right? Yeah, but then all the 'stuff' inside that 'something' will fall out, so you can't do that! RATS, another bummer!
So you do all the measuring you should, make sure things are the right size and shape for that 'something' to get from point 'A' to point 'B'. Things is fine and dandy! Ain't no bummers in sight! [Bare-foot radio feed line and antenna.]
Uh oh, but now there's a stop along the path where the 'something' is made prettier in some way (insert one amplifier along that path, or switch box, or whatever). The first thing to do is to get that "yardstick" out and do some measuring where needed, right? That usually means the doors into and out of that stop along the path. So the door into that stop along the way ought'a be the same size shape as the path and door into point 'B' is, right? Yep, so make sure. The next thing to use that "yardstick" on is the door out of that stop along the path. That exit door has to be of the right size shape so that we don't scrape any of the new paint off of that 'something', or bend the new tailfins. Okay, so measure it. It really isn't that difficult an idea is it?
So what happens if one of those doors into or out of the stop along the path is the wrong size? Do you modify the size and shape of that 'something', or modify the doors? [Input and output impedances of the amplifier.]
Are you following this so far? So what would you do? Would you change the path going to the stop along the path so that the path reshapes the 'something' to fit the doors going into that stop along the way? Or, would you have the door fixed to fit the 'something'? Do you want to work out of your wallet to fix that door or path, or would you rather the contractor who built the 'stop along the way' use his wallet to do it right to start with? Same thing holds true for the door out of that stop along the way, or your wallet get's emptied to fix the path and door into that point 'B'.
Again, what would you do?
Seems like an easy question to me (and my wallet)!
