i don't mean the models with radials eddie, im looking at the model where you just isolated the mast.
it would be interesting to take a busted 99 or 2000 bottom section and within a few inches of the wire leaving the matching section replace the rest of the length with aluminum tubing and see what effects it has .
rob , does the 2000 cover 10, 11, 12, 15, and 17m without a tuner ?
Alright Mister Marconi;
What's the possibility of having you model the Imax2000 in free space but with a 108" single counterpoise dropping straight down below it's mounting plate as if it were floating in space 100' above the space shuttle but with a very effective CMC choke in the coax 9' below the Imax2000 mounting plate?
I'd also like to see this model if the bottom tip of the 9' counterpoise were 36' above a good earth ground.
My thoughts are:
I'll grab a 4' piece of 2" diameter military fiberglass pole and install it in my metal push up mast 8' 6" below the top of the mast where it bolts all the way up into the Imax mounting plate.
Then I'll wrap a very effective coaxial CMC choke around the fiberglass so the coax shield & the 8' 6" of 2" diameter metal mast would provide right at a 1/4 wave counterpoise directly below the Imax, but fully RF isolated & insulated from the lower 36' of mast, leaving only a resonant 1/4 wave vertical counterpoise directly below the Imax.
I wonder what that would do to the pattern of that sometimes surprisingly good operating though noisy, fiberglass encased, vertically polarized, omni-directional, 27MHz .625 wire aerial?![]()
i don't think the a99 or imax are much if any different to other no radial end-feds with regards mast/coax currents, they are notorious for it,
i don't think the a99 is any worse a performer than other 1/2wave endfeds either, they have proven to work very well compared to other antennas for some people and not others same deal with the imax,
imho most of the issues with a99's is how they are installed,
both garry and carl had lip biting rfi getting into everything even stopping his ts850's compressor working, isolation solved the issue and improved their signals a little,
if the isolation made the pattern change from what you show us in your not isolated model with most energy at high angles to a pattern more like the isolated with radials model you can see why the signals could have improved,
i posted a pic of garry's imax and how it was isolated the others were all done the same with wood + choke + radials, sloping 1/4wave wire, stock imax or mm's spiderplane,
mm2000 has a spiderplane on his a99 at the moment,
just adding the choke at different places along the coax did nothing at all for garry's rfi.
Bob85 said:if the isolation made the pattern change from what you show us in your not isolated model with most energy at high angles to a pattern more like the isolated with radials model you can see why the signals could have improved,
To save me my confusionat this idea, if you'll post a simple drawing of this monster, I'll do my best. Please include the feed line and the choke location, and I guess the isolation length is 108", right?
I really don't understand the space shuttle idea at all.
Oh it's easier than you think, I'm just guilty of over-clarifying.
The Space shuttle example was just for a free space model using a single counterpoise below it.
Simply place the Imax on a 54' fiberglass tower above average ground, with a single 9' counterpoise hanging straight down the tower, and disregard any feed-line.
Interesting! Now you have me wondering about the same thing except with a .625 WL counterpoise, and/ or a .75 WL counterpoise, again, both straight down.Here is what I get with your Imax idea, I think, and they both look terrible. They are both at 54' to the mount with a 9' foot radial hanging down. One is over Average Real Earth, and the other is in free space.
