I have officially given up on my mast/Firestik setup. With the new coax, etc. I cannot get the SWR below 2.5. The level on the Galaxy shows 1.1. Not sure what to do here. Might grab a Sirio mag mount for the hood.
still using same mount? make sure the whole firestick is above the jeep roofline
it maybe seeing alot of refect if its not.whats your coax lenth?
swr 2.5 i this with a external meter?? any other devices hooked up
while dialing in antenna?
I got the tape today. Would liquid electrical tape work too? They had it on the same rack. I got the tape instead because I could take it off easy.
what channel ya doing swr check on.? could be lack of ground. thinking that mountHey guys.
For almost two years I have been running a Firestik II on the back of my Wrangler, mounted to a mast with a K-4A stud. I sanded the bottom of the mount point like I was told to do. Of course it is steel and rusts up fast, and I imagine that is not good for a proper ground.
I have tried everything and cannot get the SWR under 2.5 on any channel. I have messed with it for a long time and today decided to scrap the whole setup. Good thing too, since I broke the coax anyway.
So at the moment I have a Lil' Wil on the hood, in the center with the mag mount. This is a temporary setup.
I am looking for opinions on what would work best for me. I really don't want a whip in the middle of the hood, it might annoying fast. Should I look into something like this: Jeep Wrangler CB Antenna Mount For 2007 and Up
How would you do it? I like to DX on SSB at times, and unfortunately the hard top is fiberglass.
Here is how it looks at the moment:
Hey Hotrod.
at least 2/3 of the antenna is above the roof-line. The mount is above the spare tire. I think pics are on the first page of the thread.
Keep the antenna where it is and just pull off the mount from time to time and sand the rust off.
