Try clicking the "X" in the upper right corner of the image pop up.When I clicked on my back key...the system through me out of the thread back to the index, not where I thought I would end up.
I find my Blackberry don't like it, either crashes browser or takes ages to load, hit post reply and it quotes, couldn't get quote to work.
Worst of all my Lion Rampant avatar has stopped fluttering, hope that's not a sign of things to come on Sept 18th when my country goes to the polls to rip the UK apart and become the Independent NATION again, that sent them homewards tae think again
Looks ok on netbook, hopefully will be better on new Nokia than it is on this Blackberry, The old site loaded in seconds on the Blackberry, this one crashes more often than it loads, browser incompatibility or lack of RAM in BB, I don't know, but it is slow as fuck. I'll probably try Nokia tomorrow see if that makes things any faster.
Like all good things will take time to perfect and get used too.
Curlyjo, your image worked fine on this end, but when I clicked on it the image was much larger than my screen. When I clicked on my back key...the system through me out of the thread back to the index, not where I thought I would end up. This has happened with other functions...when I just wanted to back up to the previous page.
Also, as I am typing this post the type is moving slower than the key strokes, and the screen jiggles at times. Maybe it is my lack of memeory (or a memory hog)...like somebody else suggested.
Thanks! On my end it still shows the file image info. Don't really want to share that info. Just the picture. I will try another pic and see what happens. This is a pic of my LW 150 antenna I took with my phone holding it vertically. The site by default turned it horizontally. Let's try a horizontal pic. The top pic ( the bbq) was the second pic up loaded. So the last pic goes on top. Sometimes may want the pics in the other order.Curlyjo, your image worked fine on this end, but when I clicked on it the image was much larger than my screen. When I clicked on my back key...the system through me out of the thread back to the index, not where I thought I would end up. This has happened with other functions...when I just wanted to back up to the previous page.
I think this is going to work out good wih this phone! Going to make it easy for me to share pics with this android device. I like it ! 73'sThanks! On my end it still shows the file image info. Don't really want to share that info. Just the picture. I will try another pic and see what happens. This is a pic I took with my phone holding it vertically. The site by default turned it horizontally. Let's try a horizontal pic.View attachment 14018 View attachment 14017View attachment 14017
Moleculo -
Ramping up the font sizes on the main forum page was a BIG help. Now much easier to read. If you could do the same to the DX CHAT on the right top of the main page, that would help too. Thanks and 73s.
- 399
Ummmm . . . . Have a question here . . .
How come the xenForo site - that makes the very same software you have here now - looks like a real forum?
And this forum doesn't?
Choices?
http://xenforo.com/community/
Bet if looked like the standard forum layout, it might be a bit closer to home - so to speak . . .
$.02
I just closed my session on WWDX, and my task bar had several ads posted...and they were still open.
Moleculo did you just turned the advertising back on per chance?
Because we need to work with it as we do with other forums that do not have this myopic view.
Shortsighted; in the sense that it has affected member participation in favor of 'new', sir. My concern is for the members. If they don't care; then neither do I. It is they that will all use it; or not. Concerned about the 'not'.Myopic synonyms: unimaginative, uncreative, unadventurous, narrow-minded, small-minded,short-term, shortsighted (thank you, google).
I think all of those terms could be used for doing things the same way they've always been done. It certainly doesn't describe trying something new, fresh, and different.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
