Thanks Marconi for the data, appreciated.
If you look me up on QRZ ( PA5COR) the you see my set up there, the roof of the house is 31 feet from the ground up, the small mast is just 7 feet, so in total the mounting hardware of the Imax 2000 is about 40 feet from the ground.
The 4 wires are slanted at about 45 degree down angle, a tad over 5 meters long, or 16 feet length.
Using a European low loss coax about the same specs of LMR 400, just 2 ferrite clamps on that coax just beneath the connector type 43 material., that is what was in the junkbox at the time.
About 30 feet from the Imax 2000 is the inverted L you see on the last picture on QRZ.com, in my bio, that one is 77 feet high, undoubtly it will have some interference and coupling with the Imax.
Ground here is excellent young salty seaclay, around the house there is 3000 feet of copper wire in/on the ground as radials for the inverted L, which is fed with the MFJ 998 legal limit tuner at the feeedpoint.
With that I can use the inverted L from 160 - 10, length of the inverted L is 77 feet high and another 77 feet sloping down to a mast in the trees you see behind in the last piccie at 45 feet above ground.
click on piccie in my bio for bigger size.
There is also an OCF antenna an original Fritzel FD-4, lengthened with coil and 33 feet of wire after the coil on the short side of the FD-4 to resonate it on 160 meters, so that one works as well from 160 -10 minus 2 warc bands.
That one has it's feeding point in the other mast with the 6/2/70 cm's beams and vertical for 2/70.
Having those antenna's as close as they are there will be some interaction.
The GPK kit from the IMAX didn't really change the SWR at 18meters, in my opinion it brought the main lobe a bit down on 10/12, I could not see changes in the swr then, looking at the notes I kept doing the changes.
The main change came from the added 4 wires of 5 meters length which influenced 18 meters and 15 meters and lowered their swr a bit, as long it is under 2:1 I don't mind, 10% loss can't be noticed on the other side anyway, the tuner or P.A. takes care of the rest.
So, for an total investment of 60 dollars for the GPK kit I have a working antenna that does fine for 18 - 10 meters, without coils, withstood force 12 gale storms with 115 mile gusts, and on all the bands using mostly 100 -200 watts I worked all continents with good reports.
Being able to switch from horizontal/vertical with the OCF and Imax I can pick the antenna that works the best at that given time, on all bands I can use the inverted L or the horizontal wire to change from Horizontal or vertical mode.
Where the NVIS antenna has a dead zone, the vertical will fill that one up
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Add the homebrew receive loop with homebrew amplifier, and reception wise I have 3 antenna's for each band to pick from which gives the best reception at that time, for 160 a must.
I'm mostly on 160 meters, worked in phone from the Netherlands Brazil USA, Canada, USSR up to 5000 miles near the Chinese border with 800 watts into the inverted L, all confirmed as well.
Just to give an idea what you can do living on the edge of the city and limited space ( plot is just 100 x 21 feet wide).
Sorry for rambling on, just giving as clear picture of my setup as possible.
JustMe, a year or so back I did an Imax model with longer 1/2 wave radials and I also slanted them down.
Below is what I get using Eznec for an Imax, with no tuning device, but within reason for a bad match...I don't think a mismatch makes enough difference to worry about. However I will say these models are only general in nature as to what might happen, and would have to be tested in the real world...if we really wanted to know how this idea really works.
My Imax model is only 18' above the Earth, and I fixed these models to more like you suggest above. I made 3 models with horizontal radials equal 72", 108", and 204" or 17' feet like you suggest.
Then I slanted the radials down 70* degrees, and at 45* degrees in another 2 models to show what Eznec might predicts for your setup idea.
I also added the "source data" report (feed point match) so you might get an idea what is going on with the match you see in your setup with longer and slanted down radials.
If the base of your Imax is as I think you may be describing here...your antenna base is about net 22' feet above the ground, and the tip at near 40' feet. If I'm wrong my models are not setup exactly equal to what you have. Can you show me a picture with some added dimensions, and I'll try and get the models closer to your setup?
JustMe, there is a man in Houston, Tx, my location, that wrote an article in a popular radio Magazine years ago. Your idea is similar to his...and he made similar claims. I tried to talk to him back then, but he refused. I saw his Imax, but it was just a regular Imax with a regular looking GPK in his back yard...so I wondered about his report. He even went out to 5/8 wave with a single radial to prove a point.
So, I figured he just modeled the idea and did not test it in the real world. If I can find this work...I'll post it. However he was a draftsman and he posted his stuff on draft paper, and it is not very clear when copied.
Good luck...I'm sure some others might try this idea out...it does show some possibilities and maybe the angles this idea produces...are not really so bad for some DX conditions, but I'm not sure about very long range conditions.
