I use at times 10 awg stranded coated electrical wire and this is the band width I get 1:1 and to 1.5:1
1.0:1 SWR bandwidth of .470 MHz
1.5:1 SWR
Bandwidth of 3.350 MHz
1.5:1 SWR
Wha??!?!?We used to have "T Hunts" and I would make a lot of antenna for that. I also made direction finding gear and antenna for that as well. I would switch from my big whip to a hand held loop as I got closer to my target to help me locate them. Must of been an Army thing? LOL
CB has just hit an all time low is all. Their used to be plenty of talent and creativity on CB I think a lot of talent went to ham because of the decline of CB. The vulgarity and Jerry Springier like behavior on CB has driven a lot of talent away from CB towards ham!
Getting back to the topic...is it correct to assume that I can use 2 off shelve antenna (like a firestick) and run the top and bottom as a vertical dipole?
If so what is the advantage of using longer antennas like 4 ft vs 2 ft pairs?
Finally, how much signal will be lost if I mount it inside a building. I may be forced to mount inside a warehouse. The communication will be for local use only. Thanks in advance.
This depends on what the building is made out of. A metal building will block pretty much all of the signal, a wooden building will block next to none. Other materials will be typically in between these two extremes.
A note here, in either case, length matters, so make the antenna as long as you can. I would suggest a minimum of two 4 foot lengths for a center fed antenna, and would highly recommend pushing for two 5 foot lengths if possible. These are right in the length range where small length changes really begin to add up
Sry about the double post....but
I've read that using two 5 ft poles will get 5/8 wave. And also 5/8 wave doesn't provide any noticeable difference than 1/4 wave, Is this true? If I used a 5 ft fiberglass antenna it will come to 1/4 wave since it's not the length of the pole but the length of the coil wrapped around them?
Ultimately, I guess the real question is will a center fed vertical dipole do any better than a regular 1/4 wave wipe from inside a structure.
I did the CB thing late 70's and early 80's and now that I'm much older, I'm just trying have some fun again.
Also, you got your quarter wavelength off as well. A quarter wavelength antenna for CB is between 8.5 and 9 feet long. A five foot antenna is a shortened quarter wavelength antenna, and will not perform as well as a full length quarter wavelength antenna. As a matter of fact, the 5 foot length is right about where performance begins to drop off very quickly. You are working with a compromise length from the start, which is why longer is highly recommended here..
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
