Right now I have a cobra 19 dx IV with a cheep $20 car antenna I am a retired trucker but picked up cb as a hobby. I have $250 for either a better antenna for my house and a new cb or a better antenna and A linear amplifier. can anyone help me?
depending on the frequency the coax can make a big difference or very little difference.
on vhf uhf coax loss does come into the equation.
on HF not so much
Even the worst coax is not any more than a single S-unit down in signal from the best when talking about 11m. Once people learn what dB's are.....
A good antenna should be first considerations.
For CB base stations, you can't go wrong with a Imax 2000 vertical antenna. These can be bought for $120 or so and you should use the ground plane radial kit for another $60.00 as pictured below.
If he just wanted to throw up an a99 or imax that's fine but if he buys the ground plane kit he's into it for $180. For that money he could have bought a 5/8 maco or P500 and get more performance for his money.
. I personally wouldn't run more than 200 watts on a base for CB. Some the exports out there will do enough wattage where you will not need an amp.
True, but even a Antron 99 should be used with a ground plane just as any vertical antenna if you want it done right.
Maco 5/8 has horizontal radials which work fine but tend to attract birds to roost on them making things messy down below.
Maco antenna cost about the same as a Imax with ground kit last time I checked.
All vertical antennas? That's a broad stateme
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
