I recently heard an excellent station using a yeausu and hiel mic that sounded incredible! Until the fan from its external power supplys fan kicked in. It sounded like the space shuttle was taking off in the guys shack.
I don't want to make the same mistake.
Can you reomend a power supply that will run a hundred wattt HF at 13.8 22 amps for under $200 that won't have a fan that doesn't sounds like a rocket taking off?
I'd rather purchase a PS that has a constantly running cooling fan than one that kicks in with so much speed when it's time for it to cool the PS...
I don't know if a power supply that has its fan constantly running would be or is any quieter than one that kicks in when the power supply gets hot but if this is the case I'd rather own something like that. If there are power supplies for under $200 that have extremely quiet fans I'd appreciate it if you would let me know your favorite choices. Used is fine. I just want to keep it under $200. 73.
