You would use the same one I posted above. These are not the most convenient since they are DIP switches and you have to open the radio up to change tones.Then again, there aren't many 10 meter repeaters anyway.i was looking for one for my rci 2995dx so i can activate my local repeaters.
but i have had no luck finding one.
Instructions for installation of this board is on RCI's webpage. I do believe the board for the 2995 is he same as the 2950.
http://www.rangerusa.com/ctcss.html#ss64
The more recent AT-6666 radios come with the CTCSS board installed, however they are set to ENC/DEC, so they won't pass audio unless the tone is received. Not really worth the trouble
How do I know if my radio is equipped with the board already? I did not see it when I looked in the radio.True about not worth the trouble but not exactly correct on repeater usage.
The new President Lincoln 2 has a CTCSS and DCS capabilities which maybe useful but the operational selection is stupid. I have this radio so I'm talking facts here. The Anytone radio mentioned seems to be the same.
The tones can be only selected to be used as decode only, or both encode/decode. No encode only option.
The few 10 meter repeaters I have ever used require only a PL tone to open it which is common requirement for the nearly all repeaters anyway. Therefore since these radio's can't encode only, you won't hear the repeater.
The only thing these radio's are good for regarding the tone boards is private communications with other radio's with the same capability.
If you are looking for 10 meter repeater access other than a real HF radio, go with the RCI 2900 series and install a tone board like the one I posted earlier or try the other manufactured versions posted on this thread.
Which radio? The Lincoln 2 has a button clearly marked CTCSS/DCS. I would think the new version AT6666 Would have the same or at least a menu setting.How do I know if my radio is equipped with the board already? I did not see it when I looked in the radio.
I have the Anytone 6666, made earlier this year. There is a dcs function in the menu but I assumed that didn't mean the board was installed.Which radio? The Lincoln 2 has a button clearly marked CTCSS/DCS. I would think the new version AT6666 Would have the same or at least a menu setting.
Best way to know for sure is if you have another radio with PL tones and activate a DCS or CTCSS on that one and transmit the same tone on your At6666 and check for audio, then change tone freq. If no audio afterwards, then your tones board is active.I have the Anytone 6666, made earlier this year. There is a dcs function in the menu but I assumed that didn't mean the board was installed.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
