Unknown Device Identification
LeapFrog
Wielding Hanlon's Razor
Feb 15, 2016
1,709
903
123
Anchorage, Alaska
Hello everyone, I recently went to a ham fest and bought this item.
I think it is a pre-amp, although I have no info on it.
[photo="medium"]4314[/photo] .
The little red wire has a spade terminalone end, a switch is seen on the unit, & on the opposite end an indicator led.
[photo="medium"]4315[/photo] .
I see two transistors, a small relay and some passive components, also a few coils.
Thank You.
-LeapFrog
I believe that is used to key a linear. Not all radios have a direct key up signal line.
The incoming RF is used to trigger the relay which in turn keys the amp.
If it is a pre-amp it would not be very selective and amplify everything including noise.
Reactions: LeapFrog
The red wire has me thinking you are correct! So it runs purely off of RF from what I see, if that's the case the voltage applied to the red wire would be minimal correct (just enough to trigger the internal relay on the amplifier)?
Unless the red wire is a V.cc / V.in line to power the unit?
I did not see any electrolytic capacitors to filter DC power. To key certain amps you just take one side of the jack to ground.
Reactions: LeapFrog
Well I get a solid 3.6mV on the red wire when I send some rf through this thing, the red l.e.d. never lit up, and I did not get continuity between ground and the wire..
Seems too complicated to key an amplifier. That can be done with 1 transistor a diode and a 2 caps.
The switch on the front makes me think it could be a filter of some kind or a preamp. One transistor for amplification and the other as part of the RF sniffer to switch this thing out of line when you transmit. If it were a filter I can't see the need for 2 transistors .
Reactions: LeapFrog
Has a power wire to switch the relay once the sense line shifts the receive amp out of circuit when output RF is applied. The coils onboard are part of a filter to eliminate unnecessary freq amplification (outside of 11m?). Since the power wire is external, I'll guess that it require a 12v source.
More:
Black diode is a protection diode for the relay
Relay needs 12v
It should have a cap in there; I agree
Reactions: LeapFrog
  • @ nfsus:
    RFactive has left the room.
