MARS and CAP Modifications
Maybe it depends on the radio. I can't remember, but I read where the mod was $150. I just assumed that was their flat rate on all units. I dug a little deeper on both sites. Looks like differing prices based upon rig chosen. I suppose, higher price means more user skill required.
I understand this radio has so many bells and whistles. I just use it in 11 meters.. I don't know all of the functions even thought I read the manual...
Reactions: Sonar
It's been going on for a long time. I had a friend that bought a 746 Pro about 10 years ago, and HRO did it for him then. Truly not many MARS/CAP guys out there for the number of rigs that are converted. ;)
73,
Brett
I've noticed that some retailers are performing these mods upon request for an extra charge. Gigaparts charges around $150 and HRO is $35. Most retailers demanded proof of membership before doing the mods. Now, they leave the legality up to the purchaser. I will say, $35 is a fair price.
Times be changing....
I agree that around $35 is a fair price for it. $150 is just robbery in my opinion regardless of the radio. In all cases it is simply a matter of either resoldering some jumper pads or removing/adding a couple SMD parts that any tech should be competent enough to do.
Reactions: Tallman and NZ8N
They used to charge a fee for removing that pesky little green wire from ameritron amplifiers but I don't see that option anymore. Maybe those are sold as the more expensive export models.
Some rigs are just more difficult to make the mod. Some you have to dig into the radio quite a ways to get to the components that you need to change. They need much more disassembly. Sometimes you just need to disconnect a wire. Sometimes you have to remove a couple surface mount components which requires more skill, proper equipment, maybe time, etc.
Reactions: L2
The Yeasu FT1000MP was the easiest, it was simple selection in a hidden settings menu.
Too bad the rest of them couldn't be like that.
gigaparts charged me 75$ to do my icom 7300
i could have done it myself. but the eyed are not so good anymore. smt
parts are way to small for me.
Reactions: Mudfoot
  • @ AWP:
  • @ wavrider:
    sea que sea que,
