BBi explains antennas. (put on your high boots)
DC voltage drop per foot...
Ever put 12V into 100' of wire and get a lot less at the other end ? I'm sure you have.
Ac losses in db/ft @ frequency...
If there is sufficient loss in a lengthy coax run it's nearly the same but,
it works in both directions!
So if 20% of your energy never makes it to the antenna then 20% of the reflected energy never makes it back to the VSWR meter at the radio !
It's just numbers .
Reactions: Rwb
It's just numbers .
So I guess running 1000 ft of RG58 would not be a good idea?
Reactions: Rwb
For anyone still interested ...
I went here,
https://en.wikibooks.org/wiki/Communication_Systems/Antennas
Found Hertzian Antennas...
If you look at the diagrams and then his
Then his ....
Hence the problem - now if we can only get him back to correcting it - instead of this entire thread - we may have salvaged another user from becoming an isolationist...
He drew "capacitive" effects - we just need to re-direct his efforts...
Reactions: Slowmover and Rwb
Well good luck with that Andy. Cause he disabled comments on all his videos and I haven’t got an answer from an email yet, I was trying to spend money too.
Maybe you can call him?
Reactions: Rwb
man this is an informative thread!
based upon all the good info here, i have made a couple of changes to my antenna system.
I took a hacksaw and cut my aluminum vertical right down the center. then i folded the two halves down to a perfect horizontal angle.
now my signal is coming out the ends of the antenna and my neighbors have never heard me so clearly!
they told my my audio was louder too!
Reactions: Rwb
I got lost in this.now im trapped
.... There’s got to be a way to stop that pesky RF from going up instead of out, dang ole RF man... talking bout goin’ up and all man...
You just need one of those exposed coil antennas, the reason they work so well is because as the signal goes around that coil the centrifugal force throws the RF off the side of the antenna before it can make it to the top and go straight up.(y)
  • @ AWP:
  • @ wavrider:
    sea que sea que,
