Beyond confused
338_MtRushmore
Jun 17, 2012
1,640
1,149
193
The Dakotas
I've been messing with the antenna system on my pickup for a while now. It's been pretty frustrating because it seems like none of my results align with anything I thought I knew. The vna would say one thing, and the meter would say another. I chased my tail for a while adding chokes and a low pass filter, retuning and it just wasn't right.
Today I decided to start over. I did the 1/4 wave coax that cbers love and hams despise. I was planning to tune for x, then try my hand at a matching network. I ended up with this.
The simple fact that it is over 50 ohms confused me as I expected it to be lower than 50. The swr at the amp was actually pretty close to the vna readings, so that was a step in the right direction. For some reason I decided to add an mfj choke along with a 3 foot jumper and the swr at the amp stayed under 1.1:1. I'm thinking I'm just going to run it like this.
This project has proven to me that I know less than nothing about antennas, and what I thought I knew is totally worthless in the real world.
Reactions: G-Golly Wally
As stated above, many on the CB side swear by the 1/2 wavelength, although based on your posts on this and other forums in the past I am sure you are aware of that and simply mistyped.
What happens to the tune if you use a barrel connector and add a two or three foot jumper? Optionally you can reroute the coax in the vehicle and see if that changes the results.
The DB
The DB
I removed the line isolator and added a barrel connector and it looks like my swr curve moved up about 200Khz
Out in the open my swr with the isolator is 1:1 on 27.500 and 1.1:1 on 27.385. In my driveway I am 1:1 on 27.185 and 1.1:1 on 27.385. Seems like a pretty happy medium for now.
338, do you know why your VNA is showing in blue, "Ls out of range?"
Do you or anyone else know what this means?
Could this be a calibration error?
It looks to me there maybe another error noted in red, "HW cal NO."
Reactions: 338_MtRushmore
I don't know. This one always says that when x is zero, or at least when it is between -0.2 and 0.2. Basically anytime it reads x=>5k it also reads Ls out of range.
I also don't know what "HW cal" is either. Measurements don't mean squat if they are inaccurate or interpreted incorrectly.
With those VNAs you need to do the calibration every time you change the cable you're running from the VNA to the antenna feedpoint if you want accuracy.
Reactions: Marconi
One must never ignore a perfectly good myth when in pursuit of the Magical, Mystical 1:1 and all of the Mythical goodness it brings.
Here's wishing that RF would propagate as well as the myths do. No F2 layer required.
Reactions: Enterprise312ok
Even if I pulled the headliner to access the mount, would I just solder a resistor between the ring terminals? I don't think I can add a resistor at the antenna mount because there is essentially 2" of antenna in the mount itself. This just doesn't seem very feasible.
If I recall correctly my coax measured r=0.9 and x=0. Is that too far from zero to be useful? I thought that was the whole point of the "myth," and why hams even say to measure at the feedpoint or with a half wave coax.
  • @ nfsus:
    RFactive has left the room.
