Got it. So both near that north/south line then, right? ThanksNorth / south
Welcome aboard and DX was as dead as it comes today, All day. And even local traffic was dead. I did get 1 Radio Check on 19 AM but that was it. Don't get discouraged it will come back.New here. Just registered minutes ago. Looked for a forum because I wanted to see if others had experienced a slow down in DX lately. I thought maybe something was wrong with my set-up since I haven't heard DX for days, while a few weeks ago it was going strong daily. Sounds like others are, indeed noticing the same thing. I recently fabricated a ground plane for my A99 and have only made one contact since. So, I was kinda wondering. Looking forward to better conditions to give it a fair test. I have high hopes since my already great SWR improved with ground plane added. 1:1 across all 40 channels! An amazing yet unexpected surprise! Also looking forward to learning more from those of you who are much more experienced than I am. I toyed around with CB when I was a kid but only recently got back into it. So, still pretty much a newbie!
Yes, you can get enhanced propagation during grayline as the sun reaches across.Thanks for that. Never knew about that before. Still learning! So, is that to say that the best opportunities are between stations which are both near the grey line at the same time?
Welcome! We have been spoiled with the DX, I had been talking to the same guys in Texas for quite a while. And now nothing. But it's ok, because the lul gives us an opportunity to fix or put up a new antenna etc. that would be so hard to do if the DX was really rolling. I am currently making a few changes to my station, moving things around and changing things up. Hopefully I will be ready when the DX rolls again. We have been having a lot of luck making contacts with members here on channel 16 LSB, usually on the weekends. There is another thread here about it, hope to talk to you on the air.New here. Just registered minutes ago. Looked for a forum because I wanted to see if others had experienced a slow down in DX lately. I thought maybe something was wrong with my set-up since I haven't heard DX for days, while a few weeks ago it was going strong daily. Sounds like others are, indeed noticing the same thing. I recently fabricated a ground plane for my A99 and have only made one contact since. So, I was kinda wondering. Looking forward to better conditions to give it a fair test. I have high hopes since my already great SWR improved with ground plane added. 1:1 across all 40 channels! An amazing yet unexpected surprise! Also looking forward to learning more from those of you who are much more experienced than I am. I toyed around with CB when I was a kid but only recently got back into it. So, still pretty much a newbie!
Ah, so someone else with a ground plane on an A99! May I ask if you used it without GPK before with it? Was there a noticable difference? I recently added my ground plane but the DX slowed down before I got to really try it out properly. ThanksGreyline is how I got my first ham contact ever in 2008, 10meter ssb to Brazil. Was using a Magnum Omegaforce S45 and an Antron 99 with GPK.
It doesn't have to be strictly north/south. In fact the grayline only runs truly north/south around the equinoxes. Grayline propagation works very well when two stations are located very near the terminator as it is called.......the region between daylight and dark. I have worked into South Africa on 80m many times from here in Nova Scotia which is about 135 degrees bearing.......pretty much southeast for me. Even managed a couple contacts that were nearly two full hours after his local sunrise.......around 2am for me.North / south
Again nitpicking.north/south. Ne/sw. Nw/se same thing! Approximately north/south along the greyline terminator. There aint no east to west. Greyline= north/ southIt doesn't have to be strictly north/south. In fact the grayline only runs truly north/south around the equinoxes. Grayline propagation works very well when two stations are located very near the terminator as it is called.......the region between daylight and dark. I have worked into South Africa on 80m many times from here in Nova Scotia which is about 135 degrees bearing.......pretty much southeast for me. Even managed a couple contacts that were nearly two full hours after his local sunrise.......around 2am for me.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
