I have a problem understanding the Sirio basic endfed antennas, namely the Sirio GPE 27 5/8 wave and the Sirio GPS 27 1/2 wave.
Here goes!
BOTH of the Sirio antennas are 19ft 6 inches tall, the 5/8 wave and the 1/2 wave. Both antennas also come with an additional 3ft odd adjustable steel top rod that sits in the top to adjust the SWR, (Sirio provides a chart with guide sizes for each antenna that this top rod should be set at).
So, according to the sirio guide for a frequency of say 27.5 MHz the top rod should be set at 19 inches for the GPE 5/8 wave, so thats 19 inches on top of the 19ft 6 inches, bringing the total to 21ft and 1 inch for the GPE 5/8 wave.
For the same frequency, the same chart says that the top rod should be set at 22 inches for the GPS 1/2 wave, so thats 22 inches on top of the 19ft 6 inches, bringing the total to 22ft and 4 inches for the GPS 1/2 wave.
Question 1, how is it possible that the 22ft and 4 inches height of the GPS can be a half wave antenna? actually it's neither 1/2 wave or 5/8 wave height...?
Now the coils at the base on both antennas are visible through clear plastic and the most recent images show identical coils on both, (about 5 turns of copper then a gap then another 5 or so turns of copper).
Question 2, Should the matching network/coils on a 5/8w and 1/2w not be different for the different impedances?
Other than that the only thing I can see different on these two antennas is the addition of the ground plane radials that come with the GPE 5/8 wave.
Anyway I have a Sirio GPS 1/2 wave, and what's started me off thinking about all this is..,
Question 3, if I add radials to the base of my 1/2 wave GPS antenna will it perform better than without them? and will it actually be equal to the performance of the GPE 5/8 wave?
My query is a bit drawn out but you can understand why I am a bit miffed at this.![Unsure :unsure: :unsure:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
73s
Here goes!
73s
