Freeze spray - glad to know you have some...
That can help but if the "Heat" in the kitchen isn't the issue, but the Length of time it takes to recover it - I find interesting.
Ok, I mentioned heat because of what I saw here...
Foil Side
![1644974701679.png 1644974701679.png](https://www.worldwidedx.com/data/attachments/54/54865-b2d09445c01e53aab9d9ca5eef86478a.jpg)
Top Component Side...
This shows to me, heat fatigue - the flux and preservative used on the board got hot right around whatever is by that regulator.
The Semiconductors are NOT they only ones affected by heat, caps are too (in fact all parts are interrelated) - I think it was mentioned earlier about Capacitor ratings; one being temperature - that may affect how they operate and they don't quickly recover like their Resistor or semiconductor cousins do
Also saw this...
In the way this radio is assembled, you may have more work to do to correct such lead dress oversights - I hope that when the radio was put together - lead dress like the above didn't pinch and further damage parts from the short that it would have caused.
Foil Side
Also saw this...
