Cobra 148 gtl SSB Audio Flutter Malaysia Model
What’s the history of the radio as in any mods tunes or final swaps? How are you powering it? If it has a tiny power cord you might be starving it.
Reactions: AudioShockwav
Try this. Worked for me in the past on TX ssb warble. Not sure if you have tx or rx warble but you should do this anyway.
That's what I did to mine also, and the information I have on that issue also adds a capacitor. I don't remember where I found that but it was in my 148GTL notes.
"Cut trace on PC board between Pin 1 of IC6 and pin 2 of IC4 ( MB3756 ). Next, install a .1uf mylar capacitor at C136 and a jumper wire at J44. This corrects distortion on the SSB transmit audio"
If it's transmit warble check you're getting enough voltage/amperage to the radio !
Fastest way to make a sideband radio warble and garble on transmit is to starve it for power.........
Messing with the bias of the drivers/finals can also turn sideband transmit audio to crap.
If it's receive audio that's the problem it could be a bad speaker or audio chip.
Just my 2 cents worth. As SP5IT said, an audio sample would be super helpful !
  • @ wavrider:
    sea que sea que,
