My first Madison mod.
space cowboy
Quack Quack
Oct 16, 2012
1,368
453
93
Michigan
well, I broke out the ol' soldering iron, an ol' radio, and some good ol' imagination...
these are RGB LEDs, so while they are white now, I have some small pots I might install that will let me adjust it for any color in the rainbow and then some.
I wasn't sure if these 3 would be bright enough so I left the plastic they are stuck to larger than it needs to be with the white light. changing colors will lower the brightness, so I'm leaving it so if I change the color I can add 3 more LEDs.
thanks. it's working well. and while it's nice seeing the meters, it's a constant reminder that one doesn't work right...
ah well, the joys of owning a fixer upper.
