B
BOOTY MONSTER
Guest
found this little bit of info on using Pex with RF devices . Homerbb uses it in his gamma matches and has great results , so i thought id share this little paragraph about it from S-Meter ...
PEX Insulation Material
November 21st Fact-of-the-Day
PEX water pipe is made from cross-linked high-density polyethylene that has excellent electrical insulating qualities including extremely high resistance, exceptionally low dielectric loss, a dielectric constant of 2.3 at 20 degrees C, and a rupture voltage of 60 to 90 KV per mm at 20 degrees C. It has very low moisture absorption, can be used in temperatures from -100 to 111 degrees C, is available in a range of diameters, is very light weight, is readily available throughout most of the world, and is very inexpensive. It has a range of potential electronic applications such as coil forms, high-voltage standoff insulators, etc. Excellent antenna insulators could be made from it, except for a major problem. The ultraviolet energy in sunlight damages it within 30 to 60 days. ©2004 Martek International All rights reserved.
heat shrink or electrical tape should protect any exposed sections safe from UV rays .
