f
DxVader, you're right, the rx is not that noisy. A friend here locally has done the faster switching diode swap and double stack filter mod to several Uniden radios with great success. I couldn't find schematics and block diagrams for the pc78xl so I needed to know if someone has the info on how to do the mods to this radio.
Nomad, you are right on the money - the fuel pump, and you knew it from previous posts... I'm going to try the rf choke installation to the fuel pump wires today and see if that takes care of the unbearable noise coming in through the antenna. I'm always trying to do an easy fix, and most of the time that just don't cut it.
Oh ya, the rx is as quiet as can be with the engine shut off.
Thanks, LoneWolf TN
