2 meter dipole for ssb
Se7en
Well-Known Member
Jun 27, 2010
4,573
223
Ca
144.100-144.275
building a 2m dipole, does this sound about right:
total length = 3.25 '
each leg is = 1.62 '
i believe it is true trying to do ssb work on 2m with a vertical is not practical ?
Your 2 meter dipole lengths are about right. Starting a little long and trimming to size is much easier than the other way around.
Polarization will play a part in antenna orientation with SSB on 2 meters. That's from both an electrical and practical point of view. It's certainly not impossible to use a vertical, but there won't be many instances where it will not be a liability. Nothing says you can't hang that dipole horizontally -or- vertically, so it's definitely a possible solution for antenna 'challenged' people (and for swapping modes when you care to).
Got a couple of wire coat-hangers? Maybe a dry chunk of wood/plastic or an SO-239 laying around? How about one'a them ancient 'rabbit-ear' TV antennas? How about a non-metallic window screen on a 8th floor window and some small'ish wire??
This is a very simple a cheap first 2m antenna build that works very well.
BUILD A GROUND PLANE ANTENNA FOR 2 METERS AND MORE - SIMPLE AND EASY!
looks great! but.. i like the other build a little better as i already have them silly tv ears. just have to find a insulator still digging in my ratpack house lol
its too bad the jpole doesn't "radiate" right for ssb
I made one of these and modified it a little.
When everyone in the house wakes up I will take a picture of the one I made
S I M P L E
this can be used inside the house too yes?
Turn that 'J'-pole sideways and then try it on SSB.
Can either be used inside the house? Yes they can. They won't work as well as if they were outside, but they should work.
Cool I will try the jpole sideway
Sent from Outerspace, on the DarkSide of X.
Look into a 2 meter loop or halo,simple to build and there's a bunch of info on the web about building them,I built one years back and they work well for what they are and they are more omni directional than a dipole.
  • @ AWP:
  • @ wavrider:
    sea que sea que,
