HyGain TH3Junior - Adjustment in transmission
Gilles63
New Member
Sep 12, 2023
2
67
France
Good morning,
I'm sorry to disturb you, but I need your skill.
I’m french, sorry for my bad English ;)
I have a TH3 Junior beam with BN86 balun.
It is 3.5m above my roof.
It was set to PHONE mode, with acceptable SWR on all three bands.
I had to modify the recommended dimensions because the beam is not very high.
In addition, the steel rail ceiling support create an artificial floor !
After more than twenty years of good service, I dismantled it for repair and replacement of all the screws...
Assembly in CW mode with the recommended dimensions.
I get the following results.
On 28,100 Mhz: SWR 2.5 - On 21,100 Mhz: SWR >3 - On 14,100 Mhz: SWR 2.7
The NanoVNA antenna analyzer indicates resonant frequencies: 27,500 - 20,500 - 13,750
The antenna is physically too long.
I made a rough calculation, taking into account the wavelength and physical length of the trap elements and windings.
I found a ratio of 4.8 for 28 MHz, 4.02 for 21 MHz and 3.32 for 14 MHz.
I must remove 4.6 cm for 28 Mhz, 4.48 cm for 21 Mhz and add 3.31 cm for 14 Mhz.
This is of course theoretical, but it gives an indication…
Finally, here is my question:
Since the reflector and the director do not have the same physical lengths as the dipole, should I apply new ratios specific to these two elements?
Attached is the documentation.
I thank you in advance for your appreciated help.
Sincerely. 73 Gilles F6GYF :cool:
Reactions: Crawdad
I would say yes. The reflector and director are probably behaving the same way. Also, while their sizing isn't as critical as the driven element, they are optimized for factory specified performance.
I would set the reflector at 5% longer than the driven and the Director at 5% shorter.
I recently went thru the same exercise with a 10 year old Hygain beam.
Good luck.
David
Reactions: NZ8N and WD5ACR
Hello everyone,
Thank you very much for your answers and help.
Effectively, the variations of length of reflector and director have very LITTLE influence on the ROS compared to the driven element.
It's all correct.
With thanks.
Best regards. 73 Gilles F6GYF
Good luck.
David
You cannot really do that on a trapped multiband antenna. Monoband, no problem. I think he needs to simply shorten the 10m section slightly and the other bands should fall into place as well.
Reactions: Dmans
  • @ AWP:
  • @ wavrider:
    sea que sea que,
