Hello I have A Astron RS-70A power supply. The output Volts is currently 13.8Volts. Is there a pot somewhere inside the power supply to adjust the voltage output? I would like to get 15volts out.
Thanks
Thanks
Check your manual. I have the 50 amp models so the adjustment might be the same. With the top off, near the front top is a small horizontal board, on the underside is a small notched half wheel that will allow you to make the adjustment. I'm not sure how much more voltage you will be able to get out of it.
I got home. Unplugged it, took the top off, found the board. I had to discharge the caps and remove the board from the cap. buy removing the two screws. I was able see the thumbwheel and adjust it to get 14.5 volts out. I am happy.
Thanks for the help.![]()
Let me see.......
Increase of 7/10 of one volt @ 70 amps equals 49 more watts capability
Efficiency of your load, 50%; net difference is 24.5 watts more output.
Getting 25 more watts out of a 100 watt radio, useless!
Running 25 more watts into your previously saturated SS device, senseless.
Man with Golden Screwdriver knowledge, Priceless!
