This is what I am interested in right here.
How difficult would it be to create such a device?
How to Build an UNUN
The driven element is 102'' and the radials are 90''.
I currently have a perfect SWR of 1 on the channel I want (14 27.125Mhz) and I am getting almost 3 watts TX power.
Maybe the little underpowered power supply he says he is using has saved his radio from smokin' without him knowing. Lumpy Snake, does your PS meter peg out with max volts or amps when you key you radio?
"The 4 ground plane wires are held in place by a state of the art red brick anchoring system."
lol
I know, you know, and I'll bet LumpySnake knows that this antenna isn't ever going to be the best in the world. But it'll be usable. And with a 'shoe string', 'budget', 'cheap axed' approach like this, what else can you really expect? (Except for MY 'cheap axed' antennas which are always perfect! Right?)
For me, half of the fun of playing with antennas are the mistakes. After making enough of those mistakes it gradually sinks in that something or other just ain't gonna work that way. That's probably one of the stupidest ways of learning something, but I'm very good at it (unfortunately)!
Oh well.
You say it will work, and that begs the question. It will work of course, but work just about as badly as you could make it. He said it worked quite well, so ask yourself---why did he think he needed to fiddle with it all to find out the SWR went up? If it is good, why does he feel the need to fix it? We can't read his mind of course, but we should be able to make some conslusions about what folks say, don't say, or the way they say it.
Now LS is talking about co-phasing with another antenna and in the same breath almost he is saying in his nice little video walk-around: "...that I can't even get this thing to work."
And again a little later after some more changes he is saying the following, while the antenna remains basically on the ground:
Lumpy Snake is a bright young man and he will figure it all out sooner or later.
Quote: LumpySnake
I am actually quite thrilled with what this little 'hatchet' antenna is doing.
And yes I am kinda getting carried away with the co-phasing part.
But hey if I wasnt looking forward to trying that, then what would I have to do?
I already got this antenna to suit my needs. Now I have a reason to keep pursuing the knowledge of how to do such a setup.
Also in response to raising the antenna height. I live in a homeowners association. So I kinda have to keep it hidden from sight.
LS should try his radio with a friend's setup, on a traditional base antenna, or in a good mobile setup that is known to work well. Check his meter output for responses and see how it acts---with a good load and his power supply.
If the meter measures conducted power, what relevance is ground losses?
I always wanted to try a ground mounted 1/4 wave too.
As a local guy out here is always saying, "It's all about the fun!!" so have fun! - As it sounds like you
already are.![]()
73zzzzz
