looking for a small 1 transisitor amp, anyone have any sugerstions
Wahlrite
Wahlrite
Why are you looking for a smaller amp? I can understand why you might want one; but didn't just get a big amp recently?
Personally, I like small amps and decent antennas. No need to get the attention of irate Hams and neighbors - and then have the FCC come a'knockin.
Im looking for a total output of about 5 to 10 watts max to drive the next amplifier, its only 3/4 watt going in.
Thanks for the help
Wahlrite
Your Super Modutated MUJU rig can't do that on its own? thought you were running a 29 with all the MMM bells & Whistles? seems a bit counter-productive most any modern radio should be able to do that much without even resorting to "Happy Watts" and a Dozy....
After thinking about it, you might be trying to drive a tube box? That sounds about right for 5-10 watts of drive. If you have a really weak radio, might want to try a small mosfet amp ( something like 4 IRF520 mosfets and just choke it down) maybe instead of a 1 pill like 1446 or 2290.
Scrap that thought and go buy yourself a RCI-2970 radio.
sorry i don't know what your referring to " MUJU ", try setting the pipe down for a while, however unlikely it just might help.
Sarcasm is obviously lost on your wit..... So your saying your $450.00 dollar Cobra 29 cannot do 5 watts? If you would provide sufficient facts you would probably get more productive answers.
I belive the question can not be put any more simply,
I am looking for a small cb amp, like a 1 pill.
I flunked kindergargen, and I clearly understand the question. aparently you did not with a reply like this, and I quote " Your Super Modutated MUJU rig can't do that on its own? thought you were running a 29 with all the MMM bells & Whistles? seems a bit counter-productive most any modern radio should be able to do that much without even resorting to "Happy Watts" and a Dozy... " again i'm looking for a amp, do you have a response that's on topic?
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
