Which one?
Redeye
Oct 8, 2009
64
4
18
South 'Bama
The hole is already drilled on my car, so the trunk lid is where it will be hard mounted. Height is a concern, so here are my two choices to pair with a 2970N2...
Wilson 5000
Predator 10k single coil w/9 inch shaft
Yes, I know that a roof mount would be better, but this is not an option for me. Yes, I know that the 10k would be better with a taller shaft, but again this is as high as I can go.
So, I'm looking for opinions as to which setup (between the two above) would tune up better for overall performance. Which would you choose?
Thanks!
Wilson 5000
Thanks!
The 9'' shaft on the predator is too short for that mounting scenario, it may not tune to 1.5:1 or better so the Wilson is is a better choice.
And why is 9'' shaft as high as you can go? 17'' would work.
I tuned a Wilson 5k magnet mount on my kids car on the trunk lid right behind the window @ 1.2:1
  • @ wavrider:
    sea que sea que,
    C'mon let me take you on a Sea Cruise! (Maybe there is someone to talk to out there?)
    Just for the Halibut.
    Seems to be dead on the radio lately. I don't know if the conditions are horrible, or more likely my weak antennas. I may head up in the mountains on Wednesday and see if reception / transmission is improved.
