"GAMMAS ARE LOSSEY . THATS WHY THEY CATCH FIRE "
i see you did not graduate in physics or material sciences
"PLUS NO DC GROUND"
or basic electrical principles, there is little wonder you cannot see past a simple j-pole,
"THEY ARE STRUCTURALLY INFERIOR TO AN ANTRON"
this is true,
"IF YOU LIKE THEM YOU HAVEN'T HAD A 10-K"
yes i do on both counts,
the i10k is a great 5/8wave, one of only two available today that will survive for years in our weather, the vector will not stand even moderate weather, i don't like the vector construction quality but i like the superior performance,
"ASK ABOUT THERE 30 DAY UNCONDITIONAL MONEY BACK GUARANTEE"
funny, people don't talk about that but they do talk about your lack of communication and long delivery times,
"OH THAT'S US SORRY YOU WON'T GET THAT FROM ANYONE ELSE BUT US"
thats true, you can usually pay for and receive other brand antennas within 3-5 days,
"IF ANYTHING IS WORTH DOING IT'S WORTH OVER DOING"
not if you are cooking dinner,
"I DON'T GET IT"
that does not surprise me at all,
"PEOPLE WILL SPEND MONEY ON AN AMP BUT NOT A GOOD ANTENNA"
people that buy / build large amplifiers usually don't use onmidirectional antennas, omnis and big amps are for assholes that get a kick out of annoying locals, real dxers use beams,
"I GUESS YOU ALL HAVE A 10 AMP SUPPLY AND A 2 PILL"
thats very presumtuous and unprofessional of you and typically incorrect,
"THAT JUNK WON'T EVEN SUPPORT A 3CX1500A7"
true again, the stock gamma is ok to 1200w fm, higher power requires a high watt rated gamma,
"MY FIRST [LITTLE] METAL CERAMIC TUBE LIT THAT GAMMA JUNK ON FIRE"
a smart guy would not use high power on a stock gamma that is rated at 1000w cw by the manufacturer,
"THAT'S OK , IF YOU DON'T NEED AN INTERCEPTOR 10K DON'T BUY ONE . MORE DUCKS FOR ME TO MAUL"
could you translate this into terminology used by professionals, i tried bablefish but had no luck, bablefish translates various languages but hillbilly to english is not in the list,.
All constructed of 6063 t8 alloy and commercial grade components"
the i10k does indeed use quality components,
sirios are "Made of aluminium alloy 6063 T-832" the low wind survival comes from using .049" wall tube not some fictional low grade alloy, the strength of the i10k comes from the fast stepped taper design not any special high grade alloy,
6063 was originally created for use in furniture as a cheap alternative to aircraft grade alloys, it became popular with antenna manufacturers because it is significantly less expensive yet strong enough for most antenna applications,
the higher quality.058" wall 6061-t6 aircraft grade material used by avanti has become too expensive for all but a handfull of antenna manufacturers, it is still used in the aircraft/microlite industry where your life depends on it,
"you all speak snake oil"
your failure to comprehend anything more complex than a simple albeit well constructed groundplane does not infere we talk snakeoil anymore than the smell you create around here mean you talk bullshit,
we are not trying to sell anybody anything![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
