This is only about a year old, $125.00 / money order. comes with powersupply/charger.
GRE PSR-300 Triple Trunking Handheld Scanner (Similar to Uniden BC246)
The GRE PSR-300 triple trunking handheld scanner offers a host of features and some new technologies.This radio includes coverage of the new 700 MHz band and has upgradable CPU firmware in support of future rebanding. Ten bank and 1000 channel memories for trunking bank and channel combined conventional mode memory. Multi-tracking of Motorola (type I, II and hybrid analog system) EDACS wide and LTR are featured. You get CTCSS and DCS sub-audible encoded squelch modes. A spectrum sweep function detects nearby unknown signals. Five pre-programmed band searches are available (Marine, Fire/Police, Air, Amateur and Weather). The weather alert capability features SAME receiving with 10 FIPS area memories plus there is a Skywarn function. This radio scans at 60 channel per second and sweeps at 75 steps per second. There is a signal strength indicator meter on the LCD.
The PSR-300 comes with a flexible BNC antenna, belt clip, manual, AC adapter, alkaline battery holder and rechargeable battery holder. Requires four AA cells (not supplied).
OPTIONAL ACCESSORIES LIST AT THE BOTTOM OF THIS PAGE:
FEATURES:
New 700MHz coverage and Upgradeable CPU firmware for future rebanding
10 bank and 1000 channel memories for trunking bank and channel combined with conventional mode memory
Multi trunking of Motorola (type I, II and hybrid analog system), EDACS wide and LTR
CTCSS and DCS Sub-audible encoded squelch mode
Scan both trunking channels and conventional channels at same time
1500 ID memory in 10 ID banks, 5 sub-ID memories in each bank, and each sub-ID memory has 30 ID locations
Alphanumeric data entry
PC programmable and unit-to-unit cloning
Spectrum sweeper function
Pre-programmed Marine, CB, FRS/GRMS/MURS, Public safety, Aircraft, Amateur (Ham), Railroad, and Weather frequencies
WX alert and SAME receiving with 10 FIPS area code memories
Skywarn function
Attenuator control. (Normal attenuator and Global attenuator)
Built-in power save circuit
Frequency tune mode. (Frequency UP or DOWN)
Zeromatic tuning system
Change the direction at the searching by UP or DOWN
60 channels/sec. scanning rate and 75 steps/sec. searching rate
2 second scan and search delay
Manual selection for channel
Scan mode. [Cleared channels (000.000 freq.) are not scan.]
Deleting a frequency from a channel
1 limit search bank
Key lock for safety
Key tone and alert tone.
16 characters x 4 lines and 8 icons LCD.
Signal strength meter.
Backlit LCD and key pads
Low battery indicator by LCD
Crystal filter for 2nd IF and Ceramic filter for 3rd IF section
50 lock out frequencies per search bank, Public safety, Aircraft, Ham, Railroad, Limit search. (Totaling 250 frequencies)
Frequency lock-out review and Channel lock-out review
BNC type antenna connector
External power / charge jack
PC Interface / Clone jack (D = 3.5 mm stereo, and use GRE USB cable No. 30-3290)
Operating voltage: DC 6 Volts AAûcell x 4 pcs
Ext. power and charge voltage: DC 9 Volts (regulated)
Dimension: Approx. 65 (W) x 42 (D) x 145 (H) mm
Weight: Approx. 240g without antenna and batteries
Accessory: Rubber antenna, Owner’s manual, Normal Battery holder, Re-charge Battery holder and Belt clip
Memory backup: No battery back-up required, EEPROM used
Frequency Range:
25- 30 Amateur Band 10 Meters
30- 50 VHF Low Band
50- 54 Ham Band 6 Meters
108-137 Aircraft Band
137-144 Federal Government
144-148 Amateur Band 2 Meters
148-174 VHF High Band
216-405 UHF Mil Air Band
406-420 Federal Government
420-450 Amateur Band 70 Cm
450-470 UHF Band
470-512 UHF "T" Band
764-824 800 MHz Band
849-869 800 MHz Band
896-960 800 MHz Band
1240-1300 Amateur Band
Step Sizes: 3.125, 5, 6.25, 7.5, 8.33, 10, 12.5, 25 kHz
FEATURES:
Skywarn function
1 limit search bank
Key lock for safety
Frequency Range:
30- 50 VHF Low Band
450-470 UHF Band
