Engine noise on Cobra 75wxst in Jeep Wrangler
imustbenuts
Dec 11, 2010
6
Hi all,
I'm new here and to CBs. I installed my radio and can't seem to get rid of the engine noise. I've tried different ground location, noise filters, and nothing seems to help. Anyone have any ideas on how to fix this. I installed + to battery and - to body. The antenna is Firestik II and useing firestik cable with firering. My antenna mount shows .000 resistance and .006 at the other end of cable. Really getting frustrated with this.
Is the noise coming in via the antenna, or via the power leads? Search the forum for the problem - there are LOTS of posts addressing this with various vehicles.
Beetle was right. Before you can fix the problem you have to figure out where it is coming from.
Does the noise increase and decrease with engine RPM? What about the fan setting for heat/cooling? Another problem area can be the electric fuel pump. You might be picking up noise from the electrical system through the air and electric hookup at the same time too! Isn't this getting fun!:headbang
Terry
Hi all,
I'm new here and to CBs. I installed my radio and can't seem to get rid of the engine noise. I've tried different ground location, noise filters, and nothing seems to help. Anyone have any ideas on how to fix this. I installed + to battery and - to body. The antenna is Firestik II and useing firestik cable with firering. My antenna mount shows .000 resistance and .006 at the other end of cable. Really getting frustrated with this. :headbang:headbang:headbang
Terry
Yes, it increases and decreases with the RPMs. I have no idea what or how to check where it is coming from. Most of my searching leads me to believe it is a ground loop. But it could be anything. The antenna is mounted on the rear passenger side. What is the best way to start the diagnosis?
Take the antenna off and see if the noise is still there. That will tell you whether the noise is in the power line or received by the antenna.
    No conditions woodstown NJ.
    AKA- UDX122
  • @ nfsus:
