B
Don't mean to thread jack but am I reading this right.
Instructions
Things You'll Need:
- TV coaxial cable Pocket knife Antenna insulators Coaxial connector Rope
- <LI id=jsArticleStep1 sizset="2" sizcache="575" itxtvisited="1">1
Coaxial cable stripped to reveal each layer.
Strip the outer insulation from 102 inches of coaxial cable using a pocketknife. Be careful not to damage the metal braided shield that lies beneath. The total length of your cable depends on the distance you anticipate running it back from the antenna and to your CB.
<LI id=jsArticleStep2 itxtvisited="1">2
Pull the coaxial cable metal braided shield down the length of the stripped end of the wire.
<LI id=jsArticleStep3 itxtvisited="1">3
Push open a hole in the braided shield, and pull the inner wire out through it. You should now have a "Y" made up of the original, unmodified cable, the braided shield and the inner wire.
<LI id=jsArticleStep4 itxtvisited="1">4
Attach antenna insulators to both ends.
<LI id=jsArticleStep5 itxtvisited="1">5
Check the total length and tie both ends together. With two 102-inch sections, you will have a 17-foot loop. Seventeen feet equals 1/2 wave, which is ideal for CBs.
<LI id=jsArticleStep6 itxtvisited="1">6
Tie a string or rope to one end, and haul the antenna up a tree. The length of this rope will depend greatly on how high you are pulling your antenna, but it needs to be at least 20 feet long to get the entire antenna off the ground. Avoid using a metal pole for this, since it will interfere with reception.- 7
Plug the open end with the coaxial connector into your CB radio and start transceiving.
Read more: How to Build a CB Antenna | eHow.com How to Build a CB Antenna | eHow.com
Actually I have scraped this project and have been experimenting with dipole antennas.
T23
There are several different ways of making a dipole. The simplest of them are two equal lengths of wire roughly 8.5' long joined in the center with a strong center support that forms the joint between the two wires, At this point you fasten the two wires to the coax. The shield of the coax goes to one wire, the center conductor to the other. Make the two wires as long as 9' each and fold back the ends equally until you get a good SWR - 1.5:1 or less is very good, but 2.1:1 is acceptable.
My experience is that the best dipole build for hanging from a tree is one that feeds from the end because the dipole works best as a vertical for CB communications due to most CB antennas, esp mobiles, are set up vertically. To make this one you peel back and remove 9' of the outside insulated coating from the coax. Next you push backward toward the coating left on the coax the braided shield that was revealed by peeling back the coating you removed. When you've gotten sufficient slack in the braid roll the braid back over the coax outside insulation so that you have the inner conductor and its insulation going one direction, and the braid over the main coax going the other direction. To adjust for proper SWR trim the braid and the inner conductor equal amounts until the best match is obtained.
In this picture the shield element is replaced by a metal tube, but it still illustrates the make-up and function of the braided shield pulled back over the feedline coax.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
