TH-D72 & ISS
APRSPerth
Sep 22, 2009
10
Hi All,
Wonder if anyone has had any success with Digipeating via the ISS utilising the TH-D72 as yet?
I THINK I have everything setup ok.
I am using the 'Others' digi path with a '*' marked next to it. I have entered ARISS into the path... Im guessing thats all that is required?
I had a 25 deg pass today (27FEB) with a Mag Mount on the Car and nothing heard :-(
Am I doing something wrong or does another setting need to be tweaked?
Cheers, Duncan - VK6GHZ
I haven't tried it with the TH-D72 yet, but I don't see why it won't work with the settings you indicated. I'll start watching for some up coming passes and give it a shot.
I just got in using the TH-D72 with those settings. It was a 10 degree pass using a ground plane antenna on the roof of my house.
Thanks very much Moleculo, much appreciated.
I did have some success using the base setup with these settings although 5W and a Mag Mount don't seem to 'cut the mustard' on some passes :-(
Cheers, Duncan
Get an arrow, elk, or build a directional antenna and have some fun on the FM sats with that nice HT. The duplex capability makes it perfect for AO-51, SO-50, AO-27, SO-67 when its active over North America and HO-68 when its in FM mode(currently inactive)
Just use VFO A for the downlink and adjust for doppler and VFO B for the uplink
Duncan,
You have the right settings to access ISS via APRS.
I did it this morning (Sat 05/03/11) when we had an excellent overpass here in NSW. I got in with the standard rubber duck type antenna using 5W and got the "My position Via RS0ISS" back.
Great fun.
Gerard
VK2JNG
(y)
Hi All,
  • @ nfsus:
    RFactive has left the room.
