im wanting to try different sats and i dont unerstand linear transponder inverting ssb/cw.Fo-29 for example, how do you tx and rx? is it only cw or can you use phone voice?
Please help
thanks
Please help
thanks
Well what do I do if a satellite is running an extravariant euclidean inverse reanimentensular field, one that ordinarily randomizes phaser beams? What do I do THEN ??
Call the manufacturer for warranty work. The spacial injector detector reflector connector is obviously bad.
O.K. On a low elevation pass of Fo-29 I found a QSO on 435.845 upperside band using an indoor j-pole. Am I understanding correctly by assuming that the uplink was on lowerside band? And what was the uplink freq?
Sorry for being ignorant but im having a hard time getting my head around this.
Thanks
o.k. I havent tried this yet do to the weather but after playing with some numbers, I found that if you subtract the high uplink freq from the high downlink freq and the same for the low frequencies, you get the same numbers. ie fo-29= 289.9
What is the relevance of this if any?
