REALISTIC RADIO ADJUSTMENTS
AudioShockwav
Extraterrestrial
Staff member
Apr 6, 2005
9,030
8,798
593
Nor Cal Sierra Nevada
Realistic TRC152: {L212, L214, VR401}
Realistic TRC205: {L302, L303, TR306}
Realistic TRC210: {L11, l12, VR2-Low AMC, VR3-High AMC}
Realistic TRC216: {L9, L10, VR2-LOW AMC, VR3-HI AMC}
Realistic TRC410: {L4, L3, Q12}
Realistic TRC411: {L5, L8, Q10}
Realistic TRC413: {L3, L6, Q10}
Realistic TRC414: {L3, L6, Q10}
Realistic TRC415: {L10, L11, Q7}
Realistic TRC416: {L21, L22, VR2}
Realistic TRC417: {L10, L3, L1, Q19}
Realistic TRC418: {L10, L3, L1, Q19}
Realistic TRC419: {L305, L306, RV202}
Realistic TRC420: {L104, L106, Q107-AMC}
Realistic TRC420A: {L4, L3, Q14-AMC}
Realistic TRC421: {L9, L12, Q11-AMC}
Realistic TRC421A: {L3, L6, Q12}
Realistic TRC422: {L9, L12, Q11-AMC}
Realistic TRC422A: {L3, L6, Q12}
Realistic TRC423: {L304, L305, L306, RV202}
Realistic TRC424: {L906, L909, L910, VR9}
Realistic TRC425: {L903, L905, VR8}
Realistic TRC426: {L903, L905, VR8}
Realistic TRC427: {L12, l15, VR5}
Realistic TRC428: {L5, L8, Q20}
Realistic TRC429: {L21, L22, VR2}
Realistic TRC430: {L306, L307, RV104}
Realistic TRC431: {L907, L910, VR7}
Realistic TRC432: {L4, L3, Q10-AMC}
Realistic TRC433: {L4, L3, Q15}
Realistic TRC434: {L6, L3, L1, Q12}
Realistic TRC435: {L9, L12, VR9}
Realistic TRC437: {L7, L8, L9, L12, RV2}
Realistic TRC438: {L809, L811, RV804}
Realistic TRC439: {L302, L303, L801, RV450}
Realistic TRC440: {L104, L106, Q107-AMC}
Realistic TRC441: {L107, L104, Q114-AMC}
Realistic TRC443: {L104, L900, L901, RV450}
Realistic TRC444: {L104, L900, L901, RV450}
Realistic TRC448: {T206, T207, L208, VR5-AMC, VR204-ALC, VR4 SSB MIC GAIN, VR210-AM PWR}
Realistic TRC449: {L32, L30, VR7-AMC, CT7-ALC, VR8-AM PWR}
Realistic TRC450: {L36, TR32-AMC, VR7-ALC, VR6-AM PWR}
Realistic TRC451: {L38, L37, L27, VR5-AMC, VR10-AM PWR, VR6-ALC}
Realistic TRC452: {L212, L214, VR401}
Realistic TRC453: {L34, L26, VR5-AMC, VR6-ALC, VR10-AM PWR}
Realistic TRC454: {L901, L903, L905, VR7}
Realistic TRC455: {L407, L404, C430, R504-AMC}
Realistic TRC456: {L903, L905, VR8}
Realistic TRC457: {L32, L30, VR7-AMC, CT7-ALC, VR8-AM PWR}
Realistic TRC458: {L32, L30, VR7-AMC, CT7-ALC, VR8-AM PWR}
Realistic TRC459: {L6, L9, L10, VR13-AMC, VR5-ALC, VR14-AM PWR}
Realistic TRC461: {L11, L14, L15, VR2}
Realistic TRC462: {L11, VR3, L14, L15, VR2-AMC}
Realistic TRC464: {L5, L6, L801, RV2}
Realistic TRC465: {L26, VR5-AMC, VR6-ALC, VR10-AM PWR}
Realistic TRC466: {L104, L106, Q107-AMC}
Realistic TRC467: {L104, L106, Q107-AMC}
Realistic TRC468: {T13-15, Q10-AMC}
Realistic TRC469: {L12, L15, VR7}
Realistic TRC470: {L901, L903, L905, VR7}
Realistic TRC472: {L212, L210, VR204}
Realistic TRC473: {L11, l8, VR4}
Realistic TRC474: {L11, l8, VR4}
Realistic TRC476: {L303, L304, L305, L306, Q201}
Realistic TRC477: {L7, L8, L9, L12, RV2}
Realistic TRC480: {L7, L10, L11, VR13-AMC, VR14-AM PWR, VR5-ALC}
Realistic TRC481: {T9, L11, Q13}
Realistic TRC482: {L304, L305, L306, L307, Q201}
Realistic TRC483: {L408, L409, L801, RV201}
Realistic TRC484: {L206, L203, Q205}
Realistic TRC485: {T17, T18, L8, RV5}
Realistic TRC488: {L302, L303, L801, RV450}
Realistic TRC489: {L206, L203, Q206}
Realistic TRC490: {L36, TR32-AMC, VR7-ALC, VR6-AM PWR}
Realistic TRC492: {T11, L3, Q12}
Realistic TRC493: {T7, T8, T9, L12, Q3}
Realistic TRC494 {L5, L8, L9, Q14}
Realistic TRC495 {L6, L7, L14, VR7}
Realistic TRC499 {L701, L702, L801, RV2}
Realistic TRC850: {L26, VR5-AMC, VR6-ALC, VR10-AM PWR}
So what do you do to Q12 on a TRC-422A?
Q20 on a TRC-428?
What to do with adjustments for trc-482?
I know you can also cut d208(audio limiter)
Thank you.
That says L26, but is is beside the finals and filled with wax. Is it part of the TVI/harmonics filtering that gives ghost watts or is it a legit adjustment?
Yeah, I wasn't sure if that is part of the trap it not. It's a plastic piece with wire wound around, and a ferrite screw inside for
adjustment. Being waxed like a couple cans and the trap "bare wire" windings people love to spread, I figure is is part of the trap.
What is the difference between AMC and ALC?
AMC = Automatic Modulation Control (adjust to no more than 100% modulation). Most radios power supplies and mod transformers can not even hit 100% well without severe distortion, ie splatter.
ALC = Automatic Level Control (You need a scope to adjust properly on SSB)
Note: Simple power meters are totally insufficient for ANY adjustments, including RF power out/dead carrier.
Reactions: Cutlass327
    63Sprint has left the room.
