Does anyone know where you can buy the push to talk switch for the Astatic D104M6B?
even if you manage to get one its going to fail just like the original one .
did you try to clean the switch?
Take apart the switch down to every piece like I did and clean every part by hand than file good contacts on the ptt plates and put in new wire solder it back up u should be fine.
Sent from my DROIDX using Tapatalk 2
I have cleaned the switch using contact cleaner, but it starts to act up again in 2 or 3 months.
Truck stop CB Shop might have a donor mic for some $$$.
yep ,thats how they all are .I have cleaned the switch using contact cleaner, but it starts to act up again in 2 or 3 months.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
