CB antennas on 10 meters. WHY NOT??!!??
Staybolt
Mar 20, 2013
1,099
442
113
I made a contact with an older ham on 10 meters a few weeks ago. He gave me a solid 5/9 signal and talked to me a while UNTIL i told him i was using a moonraker 4 for my 10 meter beam. His reply was very abrupt and snotty "oh those antennas wont work on 10 meters!" He then signed off in a hurry and left me thinking WTF! :blink::unsure:
Don't worry about it, for years we have been using 11 meter antennas slightly cut down for Ten, no big deal....there just has to be one in every crowd.
If I understand the scenario correctly he made a complete ASS of himself after giving you an excellent signal report & then claiming it "wouldn't work on 10 meter"!
Obviously you have your act together & he doesn't know S*** from SHINOLA!
Geoff S. KB9KQU
Sounds like a complete goof to me. What is the difference? Metal is metal..is there a difference between the 10 meter metal and 11 meter metal that it is made out of? What it comes down to is design. Guess that was over his head.
when i got my lic in 1992 i used a cobra 148 cut to 28400 and a pdl2,then got a a99 after ice strm got the quad...ran a washington in the house and mdx200 till found a pdx400 and the hr2510,had a cb shop at the time so mostly used what ever i wanted,but mainly them...but before sold the shop grabbed a couple new ar3500 and rci2950s,and still use the and use a99 antennas,73 de JW
But the Moonraker is made of cursed tainted metal. I think is illegal and a sin against the holy FCC rules too.
Reactions: 2 people
If the antenna will load up on ten meters....RUN IT !!
I used to have a Moonraker 4 ,when I tuned it for 27.450 the gamma match still had a couple of inches of travel to it ,at least....I am willing to bet it would tune the lower part of ten without any trouble at all...
Just because that guy got skiddish is no reason not to use that antenna for ten meters or any other band you can get it to load up with or without a tuner
edit: he might have gotten embarrassed because you were running a better antenna than he was
Thats what kills me about a large portion of ham operators. They get more offended by violations of FCC rules than drug dealers and child rapist. Wannabe radio cops whos technical knowledge consist of mostly misinformation. Like a cult of FCC worship.
I have had similar experiences with equipment. Had a direct from china FDC-160 HT, and this was when they first really started becoming popular, right aftrer I got my ticket.
It worked GREAT until I mentioned what I was talking on, and like magic............
suddenly.....it became TOO LOUD, distorted, overmodulated, eventually it started to throw harmonics, both on 2 meters and out the band.
This problem would mysteriously go away when I drove within range of another repeater and started talking on it.
Then I had the Midland Syntech-1, 80 watts, 80 channels, re-aligned and modified for 2 meter band. Hit repeaters over 100 miles away with that thing, they could hear me better than I could hear them.
At the first mention of running commercial gear, its like, how do you blablabla. Your too loud, cut your power down,etc. One dude tried to say my radio was illegal, because it was fixed at 80 watts.
Ok so it more power than necessary, by the way they interpreted it, then they should cut their HT's down to milliwatts, because sometimes thats enough to open a repeater, oh does the HT not go lower than 1 watt, illegal!.
Not all people were jerks, and running such gear started alot of debate that went on long after I signed off.
This particular element of radio amateur is what hurts the hobby more than anything.
Reactions: 2 people
    AKA- UDX122
  • @ nfsus:
    RFactive has left the room.
