I used my tv antenna as a ground plane but when I replaced it with a Solarcon A99 antenna with the GPK-1 ground plane kit,substituting the GPK-1's 6 foot ground radials with four SS 101.5" Radio Shack whips,my TX and RX went up by a good two s-units. The 102" whip is okay for local talking but leaves much to be desired as a base antenna.
By the way,Marconi,those models you've presented on this thread are more than I thought a 102" whip would do.
Note:if you use just one radial/ground plane segment,point it in the general direction you want to talk towards.
op:
