HELP...I can't find this connector!
Blackcat630
Apr 2, 2013
1,153
1,861
273
Central Illinois
Hopefully someone might have one of these male "Jones" style connectors lying around that they would like to turn loose of?? It is an older Yaesu G800s rotor. I'm really trying to avoid moding the control box JUST cause I can't find this elusive connector. Yaesu no longer carries this connector and no one else commercially produces these do to the pin pattern that yaesu used....attached is a pic of the back of the box and a pic of the manual. Any help locating one of these would be GREATLY APPRECIATED!!!
Thanks for the replies. I think I will probably just change it out to the newer style molex connector. Shouldn't be to hard of a project.
I just replace them with "flat" automotive trailer wiring connectors.......
works great and is water proof too.**Jump_im**
I have several six pin Jones plugs but not with one pin aligned like that. I would change it out to a Molex connector like Yaesu uses now.
Im with C.K. on this, You are better off doing away with that old Cinch connector there pretty much obsolete and there nothing wrong with an updat to modernize and simplify things for future reference its would be a simple cut and matchup with going with modern Molex style plugs one end at a time and match up ;)
