New antenna Install
Grogan
Oct 1, 2011
1,133
343
93
Southern New Jersey
Last winter my I Max 2000 Gave a SWR of ( to much : one ) LOL
so I bought a Siro New Tornado before I went outside to look. When the weather cleared I dropped the I max and the top section and the second section lost conductivity. I made a quick wd-40 repair and today I decided to try the new antenna and RG-213 coax I bought for spring cleaning.
HF (3-30 MHz) Base Antenna, NEW TORNADO
Let you know what I think after I sit and chat. It's 27 ft. to the base of the siro. Pic makes it look closer to the dual bander and my Free TV antenna. It is higher than both.
Reactions: 3 people
Zero four Ontario Canada and bare-foot from New Jersey, not bad. The aluminum antenna is much quieter than the Fiberglass I-Max. I also up graded the coax to RG-213 and It should help. The antenna went together easy with my phillips and the 2 allen wrenches provided. It is fairly well made and should last the harsh New Jersey winters. I can already say On the receive it is better than the I-Max and more pleasant to the ears! transmit, to early to tell.
Reactions: 5 people
i agree!! i replaced my imax with a sirio 2016 much quieter on rx which really brings
in those weak signals the imax couldnt do. on tx i wont go into s meter readings
but i will say locals 60 miles away or more can now hear me
The tests are in!
I do like this antenna. Is it better then the Maco V 5/8 not sure never had one. But for what it is and nicely built,easy to build and install, sounds good and also seems to get out good. For the price it's a winner too me.
I run a Sirio Tornado myself, great RX/TX! I also had a fiberglass static stick that had no ears, huge improvement. Best bang for the buck antenna, $88 shipped to my door and looks sweet on my roof too.
Reactions: 3 people
Total agreement.My Tornado performs better than my Vector I took down for maintainence.Locals tell me TX is slighty stronger and RX is at least as good but quieter. Great skip shooter!A real surprise for an inexpensive antenna.
Reactions: 2 people
Im very suprised that the Sirio Tornado isnt more popular (Im the only one around my area that owns/uses one) maybe the price scares the big shots away, lol. Better engineered/designed than a more expensive Maco 5/8.......I got an awesome antenna for the price, Sirio should charge $130, then it would be the best? LOL!
You guys are making me want to cry...I just bought a Maco 5/8 off ebay new for $100 and I'm in the process of getting enough time to replace my Imax. I hope it is at least better than the Imax.
If you can get the V5/8 to tune right...then you should be well pleased, compared to the Imax, even if you can only claim to hear better. I think you will basically appreciate how much quieter the Maco is vs. the Imax.
Reactions: 2 people
I am amazed with my new Maco. The amount of hiss and static seems to be much less and I am of course able to hear better. I had no ground plane on the Imax but I don't think it would have mattered.:p: By the way I'm running a 257HP into 50' of lmr400 and the maco 5/8.
  • @ nfsus:
    RFactive has left the room.
