Cobra 148gtl tune up parts
Scribble
New Member
Nov 12, 2014
10
55
Hello all, I have a 148gtl and want to do the tune up on it. What parts should I upgrade, electrolytic caps, voltage regulator etc? I have all of the necessary equipment just no experience with cb's. Thanks in advance for the help.
I see no need wharsoever to change out a voltage regulator in a 148. It either works under load - or it doesn't. I have upgraded regulators in Galaxy radios that have dual finals just to keep things cool.
Changing out caps depends a lot on just how old the radio is and what kind of temperatures it has seen over its lifetime. If it is a newer 148; then it won't need caps replaced. But if it is 15 years or older and been around a lot of heat; then the caps might be drying out and may well need replacing.
The devices mounted on the chassis frame (audio chip, voltage reg, driver/final, and AM regulator devices) may need to have new heat sink compound applied if the old compound is both dry and flakey. That would be proper maintenence to keep it up to snuff . . .
Reactions: sonoma
agree with Robb on the caps and other items. how old is the radio/ this will be what tells you to upgrade the caps. dry heat sinc paste will cause a trans to fail. is it a front mic or side mic radio etc.
What robb and sonoma said.
If its an older radio, I would also replace the thick white insulators behind the chassis parts with mica insulators. May as well while adding heat sink paste. JMO
Great info and a great site. I appreciate the feedback. I hope to get my Ham license soon so I'm sure to have lots more questions. Thanks again.
If it ain't broke, don't fix it. If it just needs a simple tune, then just do the tune/alignment.
    AKA- UDX122
  • @ nfsus:
    RFactive has left the room.
