An I thought I was the only Lucky Op to have the pleasure of having that guy in Mississippi wipe me out 4 ch either side of 38 .It's been happening here off an on for weeks .
This has been asked before but here it is again: How do these obvious mental midgets manage to accumulate the funds necessary to build a station capable of wreaking this kind of havoc?
You seldom hear this happening; but if you have been listenting to the 11m band or even the 10m band, there is a dude who has bleeding over - like I haven't heard in years. One can hear hin on 38 LSB as well as one can hear him on ch 6 AM.
This 'person' doesn't realize he is wasting his potential 'maul' power on ch 6 by spreading it over such a huge spectrum.
Won't be long before the FCC chops him down.
That is, if they have any credibility whatsoever.
Enjoy the moment, moron . . .
Actually, I hear bleedover on a daily basis... If an illegal CBer complains about bleedover.... tough... Your Mileage May Vary, Batteries sold separately
I had a CBer move into a rental near me.
the first time I heard his splatter, above 28 MHz, I told him to turn it down,
of course, he didn't, soooo, his radio became pretty useless.
after about a month, he moved away.
Well, most illegal CBers with their "inbred bleedover generators" do this. I'd say 99% of those idiots making "inbred long distance calls" bleed over at least one channel.
Since CB criminals usually use Class C amplifiers, made for FM and sold as "linears" really are not linear at all. Class C amplifiers can be made cheaper. Since CB amplifiers are illegal, there are no quality control standards. It will get worse as these RM Italy and other overseas cheap brands come into the hands of people who do not know what they are using.
Couple these already dirty amplifiers to the typical CBer who has no technical knowledge who sets his radio to "all pots to the right" and you then couple the dirty splatterbox radio to a dirty splatterbox amplifier, you now get a bad mess.
Every CBer who operates illegally has no one else to blame but themselves. If an illegal CBer complains about bleedover.... tough... they do it to.
By posting this, I do NOT say the OP is an illegal CBer..... I'm just adding fuel to assist his cause
BTW: I imagine my comments will be shredded by illegal CBers. I do not care. I do not recognize illegal CBers as having any proper knowledge of radio, thus invalidating any comments. Your Mileage May Vary, Batteries sold separately
I'll put my CB against the any broadcast transmitter on the planet. Ohh wait mine is!
I've heard the same station and it's not bleedover because the interference seen on my pan adapter is stronger at points further away from the fundamental frequency. For example the signal fades proportionally as you move up from channel 6 until you approach channel 20 where you find an enormous spur just 6 db down from the signal on 6. There are a couple of other spurs being generated by this transmitter but they are much smaller than the one I mention. Between them all, he pretty much kills the entire band.
This is typical of a butchered Tram D-201 where someone clueless modified the VFO for transmit and managed to keep both the crystal synthesizer and the VFO output tied together and feeding the transmitter simultaneously. Now we get the transmitter operating on the two frequencies plus the sum and the difference between the two. Four spots all at once! If the operator only knew how much power was being wasted he would send that Tram to someone who could restore it.
Gates BC-500G..lol
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
