Used to be a shop in Lincoln called Spark Gap. Gary was the tech. Super good dude and knew his stuff. Unfortunately he died a couple years ago. Don't know if the shop is still up and running or not?
I like to mount antennas on the back of the cab. Especially on the cross bar that holds the spring and air lines. It provides a ground and is up and out of the way. I have real good luck with a 6' Frainis antennas. 5' up there is just as good I M O. Run enough RG 8X down the back & right side through the passenger door to your radio. You will not notice the difference if you have to splice the coax with a barrel. Ebay is the cheapest place to shop for this stuff. Good luck.Start with a nice antenna setup with a good match. Without that, whatever you get run won't get out 5 miles.
Does anybody know know of anyone around or near central Illinois, that i could ask to set my radio up for an amp? (im in Springfield Illinois.)
Had 2 radios done there(29,148GTL). 29 is going good but the 148 is a mess. The sideband is all messed up and understandable. I think he turned a few to many pots. This was done about 7 months ago and I'm in AL and don't get back to my home town that often.Yeah i herd of the place in Lincoln. But i haven't herd about how the techs and service are. If i find someone i will relay it to you.
that's to bad on the 148. Garys been gone for a couple years now. He was a heck of a nice dude and had a degree from university of IL in electrical engineering so he pretty much new what to do on the cb's and exports. I did some work for a friend years ago and ended up w an old 2970 as payment. This thing was a mess and someone jacked it up w the golden screwdriver. I took it to Gary and he went through it and I still have it. I talks great now. I dropped it off at the shop about 70 miles north of me and didn't hear anything for a month or two. I called the shop and they told me Gary died a couple days ago. They checked on my rig and told me he finished it the night before he died. He just hadn't got around to calling me. Crazy! probably the last rci he ever worked on. Anyways I think he was the only real "tech" they had and was the owner. Don't know who doing the work now but don't know if I would trust em....Had 2 radios done there(29,148GTL). 29 is going good but the 148 is a mess. The sideband is all messed up and understandable. I think he turned a few to many pots. This was done about 7 months ago and I'm in AL and don't get back to my home town that often.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
