you want to see a real difference try this transistor MGF1302-15 Mitsubishi let me know what you tink I put that in my hr2519 and galaxy 88hl and bang I got new radio in my hand
how did you use this in the place of a 2sc2999? it has 4 legs and a totally different design compared to a 2999. the original part is a 3 leg trans.
Thanks
I found the 959 radio here
http://www.cbtricks.com/radios/galaxy/dx959/graphics/dx959_sch.pdf
As LC says this one is very similar to my mk2 148GTL-DX but I spotted they have included a very basic upgrade to try and offset the noise seen in my hissy 148 video.
If you look at the top of the schematic near the centre you will see R26 and D7.
D7 gets biased from the AGC line via R26 and acts like a crude variable attenuator and this reduces the gain of Q9 by damping the tuned circuit of L2.
This mod will therefore share some of the AGC action with the mixer at Q8.
This will help preserve the S/N ratio better so these EPT radios won't be as hissy as the mk2 148GTL-DX on FM and AM.
I suppose I could try fitting the diode attenuator/switch to a 148 and test it but there's a risk the AGC will go unstable or introduce distortion at certain signal levels on big AM signals. The D7 mod is quite crude but it's probably quite effective. I'd still expect some hiss though and I would have thought they would have modded the 455kHz stage a little more elaborately to give a better AGC action on AM and FM.
Man, I learned a lot reading this thread, especially that guys will fight about anything LOLOLOL, my transistor is bigger than your transistor. I have been through this thread several times looking for the location and parts to replace in a Stryker 955 to do this mod. I appreciate the help.
I have more than a few of the origonal sanyo transistors left, but have my doubts as to the real effectiveness of them. Even doing an HFE test on them and using the highest gain ones I could find, I never really seen a noticeable improvement. I wouldn't bother doing this mod on any of the "newer" chasis designs being made today as the first Rx amp already has a higher gain than their older through hole counterparts (1674) had, And what this modification was origionaly ment for.
Good luck
Oh, and I think there was a thread on here somewhere where this modification was tested in great detail and still was no real evidence that the mod worked.
Thanks for the reply, I am on an email back and forth with one of the Stryker Techs, still waiting on definite and now it seems that there may be a tiny amount of improvement with just the 6263's Then again if its not discernible whats the point?
The sinad measurement is kind of useless. What if you increase the output of the speaker simply by just changing a small component? Did the receive just magically become better?Does anyone Know how to contact GOHZU ?
I know this thread has been dead a while.
He seemed to up to snuff on recieve alignments.
I would like to know if Sinad is the best for aligning the cb for recieve.
As far as s/n ratio.
I know Sinad is used for FM but have been told not for AM mode.
Also until it gets above 30 mhz its not necessary.
Like most of the experts , they are not gonna waste the time to explain.
As 543 mentioned on another thread. They do well when they preach
but Not so well when asked too many questions.
Thanks
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
