10 Metre Forum Contest this weekend
binrat
WDX Club Coordinator
Staff member
Nov 5, 2008
2,615
1,527
173
The Great White north
As the title says, contest this weekend. Here are the goods on it:
-Only contacts with other FORUM members count in the contest. The WDX roster maybe found as a sticky thread locatedhttp://www.worldwidedx.com/threads/wdx-roster-11-30-2014.28909/and
the W9WDX roster maybe found as a sticky herehttp://www.worldwidedx.com/threads/club-member-roster.132229/
-Frequency: 28.300-28.500 USB.
-Date/Time:0000 (Zulu) 15 Mach to 0000 17 March. If you're not sure how UTC time works, check herehttp://www.timeanddate.com/worldclock/converter.html?p1=3875
-Contacts: Contact logs may be in any format but it must be deciphered by common programs and must be posted in the WDX Club Contest Contacts forum located http://www.worldwidedx.com/forums/wdx-club-contest-contacts.144/
Create only one thread for your contacts. You can edit or reply to your own thread, using it as your log throughout the contest (if you wish). The format is attached as an Excel file. It may be an excel attachment OR pasted into your thread.
At the end of the contest (+3 hours), the contacts forum will be locked, so make sure you upload all of your contacts before the end date/time.
Contacts will be verified against each others' logs, non confirmed contacts will not be counted.
-Multipliers: 2x multiplier for mobile, portable, or maritime contacts.
3x multiplier for any contacts outside of CONUS and Canada.
4x multiplier for QRP. For this contest QRP is 10 watts or less.
(think KX-3, ic-703)
-If you operate as mobile, maritime, or portable during the contest, you are credited with the multiplier for any contacts you make. If you operate as a base, you receive a multiplier for any contact you make with a mobile, portable, or maritime contact. Make sure you clearly designate these in your log
-Power limit: Maximum power 200 watts PEP
-This is an "on your honor" contest and intended to be fun. Please play by the rules
- BE A COURTEOUS OPERATOR, PROMOTE THE SITE, AND MOST IMPORTANTLY HAVE FUN!
  • contest log..xlsx
If i am not mistaken ( long day at work) it states 15 march to 17 march????? Sunday through Tuesday
Yes, work is getting us all. 0000 March 14 to 0000 March 16. Basically starts tonight local time and finishes Sunday night local time.
I can not edit the change in the original post :(
Thanks binrat just wanted make sure of the times(y)
BJ I have the Mosley pro67B pointed your direction and the 3-1000Z tuned for ten meters.(n)
Thats right Binrat said 200 watts not 2KW, hmmm maybe that old 3X1 will only do 200 bird watts:whistle::D
Good luck to all and thanks Binrat for putting the contest together.
Contest contact for WDX205
wdx853
28.445
2215 Z
5-7 RS sent \5-7 RS rec.
thanks Mark
multiplier both ways(y)
WDX59
2230Z
28.430
RS sent 3-3
RS rec 5-7
Got to love that Mosleypro67b four elements active on 10 meters
Thanks Gary
