Ferrite Loopstick Crystal Radio
That's neat!
(It looks like the diode could be enhanced with an MK484 10-transistor AM radio IC. I discovered this component and just built the reference circuit with good results. I was reading about expanding the frequency response up to as high as 7 MHz.)
I still like the concept of a simple unpowered crystal set.
I've found that a genuine 1N34A diode seems to be the most sensitive, but the 1N270 is fairly close. I'm using 3 diodes in parallel.
  • @ Tim Chambers:
  • @ AWP:
  • @ wavrider:
    sea que sea que,
