Tool Recommendation
Ringworm
New Member
Jun 29, 2015
21
I need to adjust the VR907 and VR910 on my Galaxy 95T. I have tried to delicately use a small philips and standard screwdriver, but no go! From the looks of it, I need a "D" shaped tool to turn these, almost like a D shaped socket. Any help would be appreciated.
I use TV tuning tools - something like this - http://www.ebay.ca/itm/GC-Electroni...459?pt=LH_DefaultDomain_0&hash=item4d34b309bb
Don't use metal tools, plastic or composite non-metallic
Actually that is a pretty decent set of tools. It looks like the exact same set that I have used for years. BigKahuna is correct in that you should never use metallic tools especially on ferrite cores as they will break easily and on trimmer caps as the metal tip will detune the circuit. If the component to be adjusted is simply a potentiometer a plastic tool with a small metal tip is acceptable.
Reactions: Ringworm
Great, good to hear. I'm going to hit my electronics store tomorrow to see if they have anything like this, if not, then it's eBay time.
    No conditions woodstown NJ.
    AKA- UDX122
  • @ nfsus:
